Question about Electrical Supplies
Milex steam butler
How much water is the maximum you can safely put into the steam butler?
I put water into the Milex Steam Butler, but it wont steam
More than likely the water heating element is burned out.
Feb 09, 2017 | Vacuums
I need to know how much water to put in it.
press the helpful button
Fill the provided measurement cup to the maximum fill line with water. In areas with a high mineral concentration in the tap water, we recommend using distilled or demineralized water to prolong the life of the steam cleaner. Using the funnel, pour the contents of the cup into the reservoir.
Top Innovations, Inc.
400 NW Platte Valley Drive
Riverside, Missouri 64150
www.mitcoproducts.com
1-800-711-6617
http://steamerstore.com/steamfast/manuals/SF-250_Manual.doc
Jan 28, 2016 | Steam Fast SF-250 Mouse Vacuum
What type of product should i use as wall covering ? a solid surface material or a tile product. I am putting in a steam shower.
It doesn't really make a lot of difference so long as the surface is waterproof and can be easily cleaned. It comes down to personal preference.
Jan 11, 2011 | Mr Steam Mr. Steam Butler Package -...
My mr steam is not steaming. We turned it on and 20 minutes later nothing happened. WE tried jump starting it with pouring cold water and that helped but it didn't reallly build up much of a stem before...
Hi my name is Mike with Mr. Steam Tech Support please call 800-767-8326 and ask for Tech Support and I will be more than happy to help you with you problem. please note I will need your model and SN Thanks
my ext is 1280
Dan ext is 1288
Mel ext is 1275
Sep 27, 2010 | Mr Steam Mr. Steam Steambaths Bulter...
Mr. Steam won't start up
Hi my name is Mike I am with Mr. Steam Tech Support please give me a call at 800-767-8326 ext 1280 or email at mnail@mrsteam.com and I will happy to help you with your unit
Feb 19, 2010 | Mr Steam Mr. Steam Butler Package -...
Will not play all songs on mp3 cd
It's possible you are reaching the 99 folder limit of the deck. Count how many folders (artist folders and album folders) there are between Alkaline Trio through John Butler Trio. The manual says there is a maximum of 99 folders acceptable, but it doesn't say what happens if you have more.
I also assume the bitrate of the songs is 320kpbs or below, yes?
The manual also mentions "Folder hierarchy is allowed up to eight tiers. However, practical hierarchy of folder is less than two tiers", whatever that might mean.
Mar 07, 2008 | Pioneer DEH-P690UB CD Player
No Steam From Iron
I can tell you the stem rod for the steam control is choke or faulty. These prevent the water going onto the sole plate that why no steam.You've to send for servicing at your nearest repair shop or agent.
Rdgs
alan
Jan 10, 2008 | Rowenta Professional DE880 Iron
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
