Question about Jbl Eon 515 Eon515 15 Powered Portable Speaker PA Dj
How di i replace the fuse on a jbl eon 515xt?
I have an XR8300, two JBL 515XT (powered) for front of house and four 8 ohm passive boxes for monitors. What is the best way to connect all these to the Peavey mixer. Kaz
Feed FOH from Record Out, left and right. Feed monitors from the main outputs. That will give you the best option.
Aug 27, 2017 | Peavey Music
Eon 515xt - the 3 volume buttons move in and out about 1cm..is this normal or has something come loose inside?
Sounds about right to me. I have 2 eon G-15s. If you don't hear any cracking sounds you should be ok.
Apr 30, 2017 | Jbl Eon 515 Eon515 15 Powered Portable...
The tweeters are not working
The crossover caps may have failed, or the tweeters themselves burned out. Using a small 1.5 volt cell touched across the tweeter leads should produce a sound. If not- they are burned out.
Apr 11, 2012 | Harman Kardon Harman JBL LSR2328P Pair of...
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transformer...
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
Mar 10, 2012 | Jbl Eon 515 Eon515 15 Powered Portable...
Jbl eons 315 wont turn on
Check fuse located inside and let me know the result to help further.
Jan 24, 2012 | JBL EON315 15" 280 Watt Powered PA Speaker
Power went out. believe fuse is blown.
If the fuse is blown, then there is a failure that requires servicing. Unless you are adept at electronics, take it to a repair shop. Here is your service manual:
http://elektrotanya.com/jbl_eon15g2_sm.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Jul 30, 2011 | Harman Kardon Harman Jbl Eon515 Powered...
Jbl Eon 515 Eon515 15 Powered Portable Speaker PA Dj Logo
73 people viewed this question
Top JBL Music Experts
Michial Gueffroy
William Covington
Level 1 Expert
Richard Enyeart
Richard Enyeart
Are you a JBL Music Expert? Answer questions, earn points and help others
