Question about Little Giant Pes-120 120 Gph Statuary Fountain Pump
PUMP WON'T TURN ON
CLEANED THE PUMP AND NOW IT WON'T TURN BACK ON
Hotpoint MAC155 won't pump out any air
It needs to be cleaned , coils a,knd vents and filters are dirtyx. You can actually tajik it out and spray it out with garden hose and let dry completly and should work fine.
Sep 22, 2012 | Washing Machines
Pool won't hold prime. I cleaned the filter & basket. Prime is slow to come up but then surges up and immediately drops back down.
check top seal make sure its not damaged if ok check to see if intake union is tight if still bad check impeller for debris
Sep 06, 2012 | Pentair 1.0 Hp Whisperflo Pump
Won`t start when cold
No such thing on your car.
The temp sensor tells the computer what the engine coolant temp is.
If it were faulty you would get a check engine light.
I would have the fuel pressure checked before and after you crank the engine. The pump relay provides power to the pump when you turn the key on to recover some of the lost fuel pressure after the car sits. The one way valve in the pump is supposed to prevent the pressure from dropping.
If the fuel pressure drops to zero it could take some time to crank the engine enough to get it back up.
Aug 17, 2012 | Lincoln LS Cars & Trucks
Won't start
fuel pump?
Feb 13, 2012 | Garden
Buttons won't work at all. can't turn it on.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 11, 2011 | Kenmore Dishwashers
LG dishwasher model # LDS5811ST won't turn on
Hi
Daniel
Aug 31, 2011 | LG Dishwashers
Bosch Vision 500 washer won't fill with water. i! Yesterday we got a E13 error with the washer. The door wouldn't unlock, so I removed the front panel to unlock it manually. I also cleaned out...
Hi
You are right, E13 is a long drain time error and to solve this issue the pump filter assembly should be cleaned completely. There is a tiny hole you can stick a pin through in the access panel on the lower front right corner. Push a pin through the whole and turn the access panel counter clockwise and it will remove so that you can unscrew the plastic drain cap behind it. Remove the plastic drain cap and clear the drain behind it. After doing all these things if the issue returns then it means the drain pump is faulty and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 12, 2011 | Washing Machines
My dishwasher won't pump out. I've cleaned filter and cleared line. still won't pump
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 09, 2011 | Maytag Dishwashers
My dreammaker spa has power and lights but the pump won,t turn on.it makes a sound for a few seconds like it is trying to turn over then it stops.it was recently running .
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
Jan 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Little Giant Pes-120 120 Gph Statuary Fountain Pump Logo
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
