Question about Kenmore 44072 Front Load Washer
Kenmore 970-C48102-20, will not agitate or spin. Fills up with water for the regular wash and the rinse cycles but pumps the water back out quickly. An entire wash cycle that should take at least 35 minutes runs through in about 4 minutes! We have cleaned out the drain, the belt is on...
  • 30 Answers
SOURCE: Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Posted on Mar 14, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
RescueTech
  • 145 Answers
SOURCE: Kenmore Washer 110.26912690 series 90
Hi Norm. Welcome to FixYa.
The first thing to check with the kind of symptoms your machine exhibits is the operation of the lid switch. Make sure that the pin/plunger on the lid itself has not broken off, and check the actuator lever on the switch itself. It is REALLY common on your model for the actuator arm to break off or crack, and this will cause no spin/no pump problems. Your machine is built by Whirlpool and the part number for the switch assembly is a 3849238. You can get it at any local whirlpool parts center in your area.
I hope you find this info helpful and thank you for allowing us to serve you.
Happy New Year from the FixYa crew!
Posted on Dec 27, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore model 110 will not drain or spin?fills
Check your lid switch. The symptoms of your washer stopping at the rinse cycle is a commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop and compare. If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing so I can provide you with better assistance. Please include your model number if different from the one listed. I hope this information is helpful to you.
NOTE: "110" is not the model number. This is the prefix on the model number that identifies the manufacturer of your washer. 110 indicates the washer was manufactured by Whirlpool.
Posted on Nov 26, 2009
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jan 21, 2010 | Kenmore Washing Machines
    Kenmore 80's series top loader only works on wash and rinse cycle
    This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
    Jul 01, 2009 | Washing Machines
    As washer was on final spin cycle it sounded like a belt came....
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Apr 01, 2009 | Kenmore Washing Machines
    Kenmore mod 110 agitator turns while water fills tub
    Check your pump and drain for a blockage.
    You also could have a timer connection issue. Remove the timer wire connectors and reattach them.The timer simply has a quick connection block, sometimes they get a little loose and all you gotta do is push it all the way back in. Check for a loose lid hinge and safety switch also.
    Feb 09, 2009 | Kenmore 24032\24036 Top Load Washer
    Will not move to the next cycle.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    Will only work on cycle, will not agitate in the other cycles
    Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
    Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore stack washer and dryer
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 44072 Front Load Washer Logo
    145 people viewed this question
    Sal DeAngelo
    fordexpert
     Brian Main
    Brian Main
