Question about Poulan Pro 25CC 2Cycle Gas Blower
My leaf blower starts to bog down sfter about 15 minutes of using it, like its not getting enough gas
4 Suggested Answers
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
#1 Taper
  • 1040 Answers
SOURCE: poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 144 Answers
SOURCE: This leaf blower has worked extremely well but
Might be that the weighted fuel filter in the tank isn't dropping back down to the bottom of the tank when it's turned right-side up. Make sure it moves freely in the tank. Fuel filters and line can be purchased at PartsBuggy.com.
Posted on Oct 24, 2011
Echo ES210 Blower will not start
Since you are getting spark from the plug it sounds like a fuel problem. I would check all the fuel lines and make sure they aren't plugged and ensure the filters are clear.
Jun 27, 2016 | Echo Garden
My mom has Husq 125BT backpack leaf blower, the blower runs ok once it gets started but after about 15 minutes it shuts off and is extremely hot, what causes that and what do i need to do to fix it?
sounds as though she is not using the correct oil to gas mixture OR she is using two cycle oil that is for outboard engines not air cooled engines.
Nov 28, 2015 | Garden
Starts no problem. get's hot than apply gas and bogs down?
Bad gas, replace air filter, let it warm up for 30 sec before using
Sep 16, 2015 | Garden
Ryobi gas blower tuff starting and bogs down, and dies
take the muffle off and run it if ok open the muffler a bur off the screen inside with a tourch
Mar 25, 2012 | Garden
My leaf blower starts great but takes a while to warm up thats ok too. but when i run it full throttle after warm up its runs for a few seconds and bogs down and runs very slow then after about 5 min. of...
sounds like a plug problem, pull the plug and check the quality of it, also check the gap. also are you useing the correct gas oil mixture , with fresh gas.
Mar 12, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
How do I adjust the air intake screw on my poulan?
sould like the choke is getting stuck or head gasket is gone
Dec 21, 2009 | Poulan Featherlite Gas Blower, with Low...
MY RED MAX EB431 BACK BLOWER STARTS, RUNS FOR A MINUTE OR 2 THEN BOGS DOWN AND DIES?
first replace fuel filter in the gas tank you will need to fish it out with a coat hanger bent on the end to replace if that still does not fix your issue carb needs to be rebuilt
Aug 31, 2009 | Garden
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Poulan Pro 25CC 2Cycle Gas Blower Logo
26 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
