The Hideaway Kicker has all the wires installed. I connected the power to the battery, the ground to a screw, although it is questionable since it has plastic around it, control wire merged with wires that i have from my LED Glow Lights that i have connected to the fuse box, and the RCA wires are connected to the new head unit. I turn on my system with out the RCA wire installed yesterday and the light on the sub turns on saying it has power. Next day i put in the RCA wires and turn it on, no power. How do i fix it so the power comes on to the sub?
SOURCE: Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
SOURCE: Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
i had the same problem Here is the diagram i used from someone else on fixya. Thank you.
SOURCE: help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
SOURCE: My Amp Keeps shutting off
You need to get an amp with higher wattage. Obviously, your amp cannot handle those two 10" monsters. hehe Nice Subs though :D
