Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
What does 116-359-23500 kenmore intelliclean vacuum weigh?
3 Suggested Answers
SOURCE: My Kenmore bagless intelliclean vacuum is making a
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Posted on Jan 04, 2011
bbl242003
  • 1637 Answers
SOURCE: We understand that your problem is: I currently
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Posted on Jan 17, 2011
How much does a dc03 weigh
Hi there, it's Jack at Dyson.
I can confirm that the Dyson DC03 weighed 6.9kg.
I hope this helps, but let me know if you'd like any further advice.
Sep 27, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
It starting to put out a hot type smell. I have tried cleaning the filters real well and even tried to see if there was problem with the ozone filter. We have checked and could not find a jam. I know...
The hot smell could be from the belt or the motor. Turn it on for a moment, turn it off, then flip it on its side and smell the belt that drives the brush. If that is where the smell is coming from, then your belt is burning up.
FirsYou'll have to replace it. Be sure there is nothing rubbing on it like debris picked up and stuck. But, even if you do find something stuck in it, you'll still have to replace it since it's burning.
If the smell comes from the motor, do not run it anymore. That will have to be serviced.
Can you get a belt? I can look up a place online for you if you need to order one. Just provide your make and model.
I hope this works. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 08, 2011 | Kenmore Progressive Bagless Upright with...
We understand that your problem is: I currently own and use on a regular basis the Kenmore Progressive upright bagged vacuum. Model number 116.35923500. The headlight flickers and the intelliclean light...
Welcome to fixya
Hello
My name is Bruce
Jan 17, 2011 | Kenmore Progressive 35922 Bagged Upright...
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
The Intelliclean function isn't working properly. The indicators illuminate when I switch Intelliclean off, then on again, but the indicators are not changing (nor the power level) when I vacuum dirty...
I was having the same problem with my Intelliclean and I read somewhere on the internet that I should undo the bag, clean in the area where the bag attached to vacuum. When I took bag off, something was stuck there and after I removed it, everything worked fine. I think you need to clean the sensor and check your bag.
Dec 16, 2009 | Kenmore 31913 Progressive Direct Drive...
Loss of Suction
Thank you for this solution, it saved me $$$ and a trip to the repair shop.
Feb 23, 2008 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
48 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
