Question about Electrolux Eureka Easy Clean 2 in 1 Stick and Handheld Vacuum Model 108A 1 ea
Brushes won't turn eureka easy clean - Electrolux Eureka Easy Clean 2 in 1 Stick and Handheld Vacuum Model 108A 1 ea
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Good day! I have a fairly new, hardly used Eureka 3282 avz . Te carpet brush will not turn. How do I get that apart to try to see if it is clogged.
Flip it over. there is a plastic cover with either 2 or 3 screws that hold it on. Take these out. There is also a lip at the very front that the cover slips into. Carefully slip it out of it's slots. (Goes back together the same way) See if the belt is gone (broken) it also slips off and on it's mounts 4 easy cleaning. The roller slips out too for cleaning. Its made to do this as a regular cleaning maintenence.
Aug 31, 2011 | Eureka 5902AVZ Bagless Upright Vacuum
Eureka Altima - before I can get one room vacuumed the belt breaks. Why?
If the belt is breaking that quickly, there is one very prominent culprit that could be causing the problem. Check to see that the beater brush, the roller brush that the belt is supposed to drive, is turning freely on the unit. Remove the brush and clean as best you can. Add some WD40 at both ends of the beater brush by the hard rubber holders and turn the brush by hand to work it into the joint. Reassemble and be sure the belt is put on so the brush turns in the proper direction. Paul
Oct 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Brush roll turning very slow
You might need to clean out the roller brush. Here is the manual that has instructions:
Owner's Guide (1.5 MB download)
If you need a new belt you can get it here:
Eureka style D belt
Nov 21, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Mar 08, 2009 | Eureka 402A Bagless Upright Vacuum
The brush roll on my Eureka Bagless The Boss 4 dimension cleaning vaccum itsn't working. How do I fix it?
Take either the plate over the brush roll off, if it doesn't come off, then the top cover comes off, should be 2 or 3 screws on the top to remove. Then you can get to the belt and brush roll. Check the brush roll, make sure the ends turn freely, if not replace it. The belt is either broke or stretched to the point that it won't turn the roll, replace it.
Jul 13, 2008 | Eureka Vacuums
Electrolux Eureka Easy Clean 2 in 1 Stick and Handheld Vacuum Model 108A 1 ea Logo
44 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
