Haier automatic washer rwt 350 aw won't drain
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: I have a Haier RWT 350 washer and the tub sinks a few inches when filled with water. At least 3-4 inches! Can this be adjusted?
If you just purchased it, either have it sent back for a replacement, refund, or have the company send out a repairman to service it.
Posted on May 01, 2012
Haier HLP20E washing machine won't spin & drain.
Haier HLP20E washing machine won spin drain Google Search
Cause 1Lid Switch Assembly The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Parts Cause 2Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Parts Cause 3Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Parts
Jan 13, 2018 | Haier Washing Machines
Do the haier rwt 360bw have to have clothes in it to start the wash cycle
No but in saying that what would be the point of starting it with no washing in it?
Nov 27, 2017 | Haier Washing Machines
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Washer will fill and drain but won't wash and rinse
Check for a modular unit in the machine that controls the wash action of the machine. If it has malfuctioned there will be no power for the motor. Check with the spares departtment if your machine has this unit
Mar 02, 2013 | Haier HLP21E Top Load Washer
Apr 28, 2012 | Haier RWT350AW Washer
Window / through wall unit made by haier, i can't find a model number. but it's making an awful racket like a blade or something hitting something. also slightly blows out a light fine mist of...
Where the unit drains is clogged it sounds like so your fan blade is hitting the water and scooping some of that water indoor. look where the condensate drains and clean that and it should be fine
Aug 14, 2011 | Haier ESA3125 Wall/Window Air Conditioner
I need a drain pump for XQBM22-C how much is it and is it available ? and how can I get it?
automatic appliance parts.com
washer specialties.com
sears parts direct.com
marcone.com
Jan 28, 2011 | Haier XQBM22-C Top Load Washer
Dryer heats up but will not dry clothes....model rde 350 aw
the vent is clogged, unhook vent and clean out
Aug 27, 2010 | Haier Dryers
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
