Question about LG 15LW1R 15 in. LCD Television
TV controls not working
I've been given a Bush LCD30TV005 with no manual and no remote control. I can switch on the TV but can only get a picture through pressing the 'source' button. None of the other buttons on the TV appear to be working - I can't change the channels or alter the volume using the buttons down the side. I'm wondering if there is maybe a child lock or something on it. I can switch channels through my freeview box but can't use the TV as the volume is set way too low and I can't turn it up. Can anyone help?
  • ILO-vemytv May 28, 2008
    when i turn my ilo-26hd on, i can not change the channels or turn the tv on/off on the side controls manually or with the remote. although, the remote will turn the tv on and off but won't do anything else. also, when i turn the tv off, the screen goes blank but the volume is still playing from the one channel it is stuck on for about 15 or 20 secs and then goes silent. HELP!
  • mac2net May 11, 2010
    goodmorning sir
ARGOS SELL SPARES FOR ALL REMOTE CONTROL DEVICES ON THE ARGOS SPARES SITE. PRICEY BUT WORTH IT!
Posted on Dec 08, 2007
SOURCE:
Have an urc-6430 remote control need the codes to program my Bush tv
0287,0281,0286. Try these codes. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Nov 07, 2013 | One For All URC4220 Remote Control
Bush Codes Tv
0039,0035,0034,0028,0021,0022. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 24, 2013 | Televison & Video
Orion remote won't turn TV on
You have to setup the DVD by its setup codes with Xfinity. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter" Setup code list, and setup proceedings to Xfinity remote control is given in detail.
Apr 14, 2013 | RCA RCU300WBL Remote Control
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Hello, I have a Bush TV 2038TSIL which I want to start using as a second TV. Since the TV hasnt been used for a while I'll need to do the tuning again. Can this only be done with the remote control...
Hi
If there is a "Menu" button on the front panel of your TV, you can enter into its menu; surf trough and come towards tuning option. If there is no such button on the front panel of your TV, you have to buy one universal remote control to work with it. Be sure that buying new remote have setup codes for Bush TV. There are very rare remote models have setup codes for Bush Tv. Look at its manual before buying it. OK.
Jul 14, 2011 | Bush Televison & Video
New bush tv cannot find code for my sky remote
Hello
Sky remote codes for Bush TV are:
246 263 377 037 064 065 310 300 383 399 391 402 547 292 239 312 609 322 339 515 236 389 035 191 232 245 288 714
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible
OK.
Jun 26, 2011 | Televison & Video
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Jul 19, 2009 | Televison & Video
Remote control manual for bush internet tv
To reset your bush internet t.v. remote after replacing the batteries you must press left down right and number 1 at the same time. You must do this whilst pointing the remote at the t.v. set.
Apr 09, 2009 | Bush 1433GRN2 14" TV
No picture on Bush WS6667 TV
hello make sure the scart lead is connected tight
Jan 20, 2009 | Bush WS6671 28" TV
LG 15LW1R 15 in. LCD Television Logo
314 people viewed this question
Ekse
