Question about Dishwashers
Ikea whirlpool dishwasher dwf 402 - Dishwashers
3 Suggested Answers
SOURCE: DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Posted on Feb 12, 2011
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Posted on Mar 19, 2011
Dwf 415 dishwasher, overfills with water
gee a whirlpool doing that
check the user manual
the control board failure
water level shut off sensor faulty
water pump failure
check for drain out blockages
http://lastmanuals.com/manual/WHIRLPOOL/DWF-415-W
Oct 13, 2016 | Dishwashers
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
NO WATER IS PUMPED UP INTO THE MACHINE (IKEA DESIGN DWF 406 MODEL)
Check the fill switch on the inside of the dishwasher. It should be located on left front bottom of inside. This gets stuck alot.
Jul 23, 2010 | Whirlpool Dishwashers
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Whirlpool DWF 407 IKEA Dishwasher serious problem.
a worn film capacitor on the circuit board is the cause of the problem which often manifests itself after several years using the dwf 407. Replacing the film capacitor on the circuit board is the solution! Such a capacitor costs about GBP 2. The removal of the circuit board that is in the door is not very difficult, four torque screws along the inside top of the door (not the two for the door lock) a click system in which the print is stuck in the door. On the print are a few connectors with wires to loosen-take picture or mark them for reassembly purposes. There are several types of DWF 407, sometimes the print is slightly different. But the culprit is always the big gray block. The value that you must have is 250/275 V 1,5UF. Many electronics stores have them or can order them. Soldering you can do yourself if you have some experience or ask your local handyman. It is not very difficult, you have plenty of space on the board and only two feet soldering required. After that my dishwasher was as new at the fraction of the price
Oct 28, 2009 | Dishwashers
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
IKEA Whirlpool DWF 403 W Dishwasher buzzing
When it's buzzing, you have to let it buzz until it stops. Then you pressed stop then start. Et voilà!
"S" means salt, but you can use any salt you want.
Jun 11, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Please help
try dropping power to the unit for a minute and see if it will reset itself. if not, you have a logic board failure. that or a door switch. check the manual for an indication on the warning alarm.
good luck
mark
Nov 18, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher DWF B00 W
get back to me and tell me if it drains or stays full of water and did you do work on the plumbing in the kitchin
May 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
