Elekta split ac problem
My ae does not work and the display shows e3
5 Suggested Answers
  • 521 Answers
SOURCE: Fault E3
it indicates the problem of a compressor as the fan works fine .i feel the compressor is not able to cool the device.i will suggest you to get it checked by a proper technician.
Posted on Aug 09, 2008
SOURCE: Elekta Window Air Conditioner, Thermostat won't cut off.
Good morning, I'm using Elekta window A/C 1.5 ton and I'm using this for almost three years and now there is eritating sound while the A/C is running. Could you please advise what is the problem?
BR/Art
Posted on Sep 19, 2009
SOURCE: My sairon split system ac unit does nothing and
if split ac display shows e3 what is the solution for that problem
Posted on Jan 13, 2011
  • 20 Answers
SOURCE: My voltas split AC did
power indoor and outdoor units down record all info in and out make m# s# froward to me ..also need history of unit when installed past problems.
Posted on Jul 03, 2011
We have 2 ton split Ac elekta brand need out side unit fan motor conection daigrame please help us thanks
Most units wire up the same 1 or 2 capacitors to start compressor and or fan motor and a connection point for AC power and control wiring Here is a link to one of the better guides I know of http://www.alpinehomeair.com/related/AC%20Installation%20Guide%20Update.pdf their are quight a few videos on you tube on hooking up AC units also
Jun 27, 2016 | Heating & Cooling
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
Mar 05, 2015 | Heating & Cooling
E3 display on lloyd make split ac how to solved problem
Pipe temperature sensor checking channel is abnormall [E3]
Check Out Manual _ http://www.mylloyd.com/productpdf/AC.pdf
May 13, 2013 | Heating & Cooling
My voltas split AC did not work and shows E3 in the display. i try to change mode but no use
Jul 03, 2011 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
Dec 10, 2010 | Heating & Cooling
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
there is a temperature sensor try to imerge it into a hot water glass and the try again.
May 24, 2009 | Heating & Cooling
Error : E3 FAULT
i have problem ac indoor come on display e3 error problem kindly give me solution
Sep 16, 2008 | Kenwood KW85 Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
