Question about Polaris Pb4 - 60 Booster Pump
Runs but wont pump water
My pump is running but wont pump any water to the sweet, The pump is leaking where the seal goes, do you think that the leaking seal will cause the sweep not to work.
    Top Expert:
  • Polaris Master
  • 5,096 Answers
Bad seals replace pump
Posted on May 22, 2016
3 Suggested Answers
flacooo1
  • 172 Answers
SOURCE: booster pump for cleaner runs for 30 seconds and
you have an air leak where is getting this air from wll is fron the 3/4 inch line in front of the pump the line goin in this line is loose but don't try to cut the pipe and put more teflon tape because this pipe got hot and now it won't fee tied is always better to replaced I was a pool techinicial in california now I have move to Georgia so I know this verrywell
Posted on Jun 16, 2009
seanpwright
  • 2030 Answers
SOURCE: replaced my boost pump and now eveb before I turn
You either have a bad seal or bad connector..make sure you check them both very well....and if you didnt use a new seal, the old seals are pron to leak when re used.
Posted on Feb 03, 2010
I need to know what the pipe is called that the lower rad hose hooks up to at the back of the 3.0L automatic
its the water pump inlet tube , if its leaking coolant its more than likely the water pump if thats why you asking the question , worked on plenty of those engines and the weep hole for the water pump when the seal goes it leaks out and runs down under the intake manifold at the rear of the engine , timing belt water pump service end result
Jul 07, 2014 | 1998 Plymouth Grand Voyager
Fisher and Paykel DW920 dishwasher pump wont stop
This means the flood circuit is triggered. There is a leak in the dishwasher causing water to collect in the motor chamber. The leak is usually through the door seals or broken hose. Disconnect mains electric and water connections and pull dishwasher out from under kitchen bench. Tilt it from side to side to get the water out from under the base. Wait a little for water to dry up. Reconnect mains power and turn on to see if pump stops running. As mentioned source of leak needs to be fixed.
Mar 15, 2013 | Fisher and Paykel Dishwashers
My 1995 Chevy Monte Carlo is sometimes running hot. My overflow tank remains full. But the radiator is losing water somewhere but I see no water on the ground or anywhere else. When I take the radiator...
indicates an air lock in the cooling system
could be from a failing head gasket ( do a compression test)
have a coolant pressure test done to find the leak
possible a water pump seal leaking when running
check sump oil for greying color ( failure of the housing behind the pump impeller
Apr 15, 2017 | 1995 Chevrolet Monte Carlo
I have been putting alot of coolant in my radiator I dont think its a hose because it seems to be coming from the middle to bottom part of the car could this be a water pump problem?
The water pump is in the center of the engine. It usually has a small hole in the casting on the snout. If the seal went bad water usually runs out of the small hole and down the center of the front of engine. With the engine OFF, put your hand under the pump, and feel the snout to see if water winds up on your hand. If possible use a flashlight and check for a leak all around the pump, and bolts that hold it in. In a rare case the pump gasket could be leaking. If the pump appears to be dry, check the small hose that goes from the center of the pump to the block.
Jul 07, 2010 | 1999 Cadillac DeVille
I have a unionpower up-150 pressure washe, and it wont pressurise
Either your valves are stuck or broken or the seals inside the pump are worn
Jul 20, 2009 | Garden
Manitowoc SD 0852A ice maker compressor will not kick-in
Here's my thoughts, I hope it helps. I'm going on foggy memory here, so I may not be entirely correct.
I worked on something like this a few years ago. The icemold (plate) is vertical, there is a circulating pump that runs water over the mold, with the water freezing as it passes. The sealed system is a heat-pump scheme, it freezes the mold to form the cubes, and reverses to heat for release. And when it works, it makes ice fast. It runs constantly until the ice hopper is detected to be full. (there should be a bail to detect the ice level) The system will not run in the event that it thinks the hopper is full (bail up) but the pump motor runs continuous to avoid it freezing. There is probably either a false detection of "full" or there may be a leak in the sealed system and the system will therefore not run.
Jun 28, 2009 | Freezers
Polaris Pb4 - 60 Booster Pump Logo
93 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
