Question about LG DLGX5171W 27" Front-Load Gas Dryer
Remove top on lg gas dryer model dlgx5171w - LG DLGX5171W 27" Front-Load Gas Dryer
3 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: LG 6988 gas dryer conversion
you will need to get to the gas valve right front after the panel is off the orfice is in the end if the burner
Posted on Jan 25, 2008
  • 489 Answers
SOURCE: Gas dryer LG DLG3788W
Take a 2 inch putty knife and slide in the separation gap just above the door.  There are 2 catches on each of the panel about 3 inches from each side.  Push in to release the catch and the top panel will pop open.
Posted on Jun 11, 2008
Filter light flashing, filter is clean, vent duct clean, and blow no heat.
Shelia,
It seems that the "piping" from the filter to the duct pipe may be blocked... Can you vacuum "below" the filter, to remove any "fluff" that may have gone past the filter; and, then try the same, from the duct pipe back into the machine.
That worked for my dryer (not the same make or model).
Hope this helps...
Topbarhive
Jan 12, 2016 | LG DLGX5171W 7.3 cu ft Gas SteamDryer with...
How to remove the back panel
remove top, then front control panel, then front of dryer. then you will have full access.
Jul 03, 2014 | LG 7.3 cu. ft. Gas Dryer, White Model...
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
Need to remove front of dryer to install propane conversion kit. model dlg5966
Remove top 3 screws in back, Slide top ack 2-3" and lift off.
Remove control pnl.
Remove front panel.
Gas valve is in the lower right corner.
Follow conversion instructions.
Jan 11, 2010 | LG Dryers
How do I change the orphus on my LG gas dryer model number DLG2526W
You have to get to the gas valve which is located in the front right bottom of the machine.  You will need to remove the top.  The screws for the font panel will be on the inside top and might be a couple behind the door.  If you need more detailed instructions let me know and I can send you parts of the service manual
Oct 25, 2009 | LG DLE0332 Gas Dryer
Lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Apr 18, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Blows cold air and produces little lint in the vent
To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Dec 28, 2008 | LG DLE5977 Electric Dryer
LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Dec 28, 2008 | LG DLG5932W Gas Dryer
LG Dryer DLG7188RM LP conversion back to NG
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Nov 20, 2008 | LG DLG5932W Gas Dryer
Jan 25, 2008 | LG DLE0332 Gas Dryer
LG DLGX5171W 27" Front-Load Gas Dryer Logo
57 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
