Question about Tablets & eReaders
Driverdoc serial - Tablets & eReaders
How to register my apple Ipad device when it keeps on asking for another serial number even when i had typed the correct serial number already
On your iPad's Home screen, click on Settings > General and then check through the list, to make sure that you are typing in the correct number:
Model
Serial
SEID
Jun 29, 2017 | Apple Tablets & eReaders
My serial number doesn't match any listed. I want to know what kindle I have so that I can order a case with a light.
B0C6, 90C6 Kindle Basic (2014) KT2, BASIC If you happen to know why some of these begin in 90 instead of B0, I'm all ears ;) [Support added in KindleTool 1.6.3] Kindle Serial Numbers
Nov 19, 2016 | Amazon Kindle 3G
What is the operating system for product serial # hm251el7b4349
Product serial of what? No way to identify a product by it's serial. Need make and model. Anyway, it it's a tablet, most probably it's Android.
Apple products use iOS and Miscrosoft Surface uses Windows
Nov 09, 2015 | Tablets & eReaders
Bought two digiland tablet which have exact same serial numbers
Are you sure it is the serial numbers you are looking at and not the model numbers?
Apr 08, 2015 | Tablets & eReaders
I have lost my kindle and need the serial number
Sign into your Amazon account and go under manage your device and the serial is there.
Dec 27, 2014 | Amazon Kindle Fire HD
Where is the serial number?
if you still have orig box, check labels... otherwise try taking back off, look under the battery
May 28, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How do i get the serial number for hp slate tablet 7"
The serial number is located on a sticker adhered to the back of the tablet.
You can also find the serial number stored on the tablet. HP Support document
May 02, 2014 | Tablets & eReaders
Can"t locate the serial number on my tablet
look on the box you bought it in or look through the setting in the tablet the serial number will be in one of the two places.
Nov 11, 2013 | RCA Tablets & eReaders
Serial number on a asus vivo tab rt
- Turn on your tablet
- Go in "desktop mode"
- In the "search bar" (swipe outside right to inside going left, tap "Search")
- Type "run" and tap the "Run" app icon
- In the textbox of the "run app", type "cmd" then tap "Ok"
- Type "wmic bios get serialnumber" in the command prompt
- Serial number will appear
There is also a sticker at the back of the tablet containing the serial number (bottom left). This number should match the one obtained from the wmic command.
Nov 30, 2012 | ASUS VivoTab RT
I cannot find the serial number of my tablet, I did purchase a reburished tablet from a reputible source
The serial number can either be found on the back of the device, or can also be found in the android settings. to get to the serial in the android settings:
1. Touch the settings app.
2. Touch the System Settings option.
3. Touch the Device Information option.
4. In there there should be a list of device information including the serial number.
I hope this information has been helpful.
May 24, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Tablets & eReaders Logo
15 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
