Question about Frigidaire 50 Pint Capacity Dehumidifier
Reset filter frigedaire - Frigidaire 50 Pint Capacity Dehumidifier
The clean filter light on my Garrison dehumidifier and I took off the side grills and attached was a mesh screen....I cleaned them and the light is still on.....the interior grills don't seem
the filter minder needs reset after you clean filter everytime Hold down for 5 seconds on button right next to light this should clear alarm
Oct 12, 2014 | Dehumidifiers
I have a Frigidaire energy star 50 pint dehumidifier serial number is lad504fdl. It runs for about 5 mins. then stops. I cleaned the filter, and it has a filter reset, but I can't get it to work. Please...
Hello Jackie Grier, I appreciate your post!
I understand that the filter reset button is not working on your Frigidaire dehumidifier. I would perform a reset to your dehumidifier which can be done by disconnecting power from it for roughly ten minutes, you can do that can be done by unplugging it or flipping the household circuit breaker.
If that does not correct the issue it sounds like a possible problem with your control panel or sensor. Are you under warranty? If so I would reach out to your manufacture to see if they have any potential remedy for assistance. I hope this helps. -Matt
Sep 30, 2014 | Dehumidifiers
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
How do you unclog the dehumifier?
Hey friend, thank you for the post!
I understand that your dehumidifier continuously is set at 50-60 and the clean filter light has not stopped. I would like to ask you some additional questions in order to provide you better assistance. First, does the appliance still collect water? Secondly, have you tried to reset the appliance? I look forward to your comment back so that I can further help you. -Matt
Jul 29, 2014 | Frigidaire FDL50R1 Dehumidifier
Bought the Frigidaire 6000 BTU Window Room Air Conditioner LRA067AT7 6 months ago and it worked fine until last week, It will not turn on although plugged in and the wall outlet is good. Is there an auto...
Good Morning Luca,
I understand your Frigidaire air conditioner, model# LRA067AT7, will not turn on. I also see that the wall outlet is good, so you are wondering if there is an automatic shut off if the filter has not been cleaned. Your air conditioner does not have an automatic shut off, if the filter has not been cleaned. Please start by cleaning the filter. You can do this easily with the following instructions:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
    1)Push the vent handle to the Vent Closed position (where applicable).
    2)Open the front panel.
    3)Grasp the filter by the center and pull up and out.
    4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing
    5)Or instead of washing, you may vacuum the filter clean.
    Also, be sure your air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. Do not run your air conditioner without outside protective cover in place. This could result in mechanical damage within your air conditioner. Do not use an extension cord or an adapter plug.
    The power supply cord contains a current device that senses damage to the power cord. To test
    your power supply cord do the following:
      1)Plug in your Air Conditioner.
      2)The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
      3)Press the RESET button. Again you will notice a click as the button engages.
      4)The power supply cord is now supplying electricity to the unit. 4)
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
      -Best Regards-
      WP
Jul 09, 2014 | Frigidaire 6000 BTU Window Room Air...
Water filter on aprilaire model 700 light keeps flashing
You need to reset by turning thermostat dial all the way to test reset. It will reset itself, then go back to your setting.
Mar 05, 2014 | Aprilaire 700 120V Power Fan Humidifier...
Ihave a comfort aire BHD-301. when i turn it on the filter lite keeps blinking and the filter is clean. is there another filter besides the one on the side?
No, there's only one filter. So be sure that you reinstalled the filter properly, so that it is making contact with the filter switch. If that checks out OK, turn the unit OFF & unplug it for 15 minutes.
After the time has elapsed plug the unit in and turn it ON. Hopefully, during that timeout, the electronics reset and reverted back to the original factory settings, If so, you can now set the controls as you desire.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Comfort-Aire BHD-301 Dehumidifier
. What does P1 on the LED screen mean?
P1 indicates that the air intake filter needs to be removed and cleaned. Turn the unit OFF and Unplug it from the wall, before removing the filter. If you wash the filter in warm soapy water (dish washing liquid is fine), be sure it's thoroughly rinsed and dried, before reinstalling it. Never operate the dehumidifier without the filter installed. Once the filter has dried, reinstall it. Plug the unit back in and Turn the Master ON/OFF Switch to ON. If necessary, you can reset the settings, you originally had the unit set on.
Hope this helped you.
Jun 20, 2011 | Danby Dehumidifiers
What does e1 mean
For many window air conditioners this code is simply a reminder to clean the air filter. After like 750 hours of run time this code pops up and you have to clean the filter and then reset the unit before it will work again. To reset the code you need to simply unplug the unit and then plug it back in again.
Hope this helps; good luck.
Jun 13, 2011 | Haier 45-Pint Dehumidifier
What does "CF" mean when flashing on Kenmore dehumidifier?
MOST LIKELY CHANGE FILTER. MAKE SURE YOU HAVE INSTALLED THE CORRECT REPLACEMENT PROPERLY. LOOK IN YOUR OWNERS MANUAL FOR RESET INFORMATION.
Mar 02, 2010 | Dehumidifiers
Frigidaire 50 Pint Capacity Dehumidifier Logo
44 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
john h
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
