Question about Polaris Pb4 - 60 Booster Pump
I have a PB-4 polaris Booster pump
The problem is that the motor runs and leaks water at the pump end of the motor and dose not work the pool sweep at all. could I be leaking so much water that it wont work.? It leaks prety good but i wouldn't think that it would stop the sweep from moving. I have cleaned all of the filters and lines and it still wont pump water.
    Top Expert:
  • Polaris Master
  • 8,502 Answers
Replace pump
Posted on May 22, 2016
john224
  • 1378 Answers
SOURCE: POLARIS PB-4 3/4 HP BOOSTER PUMP
A motor can run that hot and still be within the temperature it can handle. It likely has an internal overload device that will shut it off if it exceeds that temperature. If you see something like "thermally protected" on the motor nameplate, you are ok. If it is getting noisy as it runs it may need servicing.
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
john224
  • 1378 Answers
SOURCE: polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Posted on Aug 24, 2009
john224
  • 1378 Answers
SOURCE: Once the booster pump (for polaris 280) is turned
There is a bad seal and/or gasket in the pump allowing it to leak. It is usally the seal. Take it to a local electric motor or pump shop and the repair is probably under $50 total. You could also buy the parts to try it yourself, but the seal that pump takes (AS-1000) is a little tricky to seat properly. Besides, if your bearings are also damaged, the shop could fix that as well.
Posted on Oct 03, 2009
john224
  • 1378 Answers
SOURCE: Installed a new 3/4 hp Polaris pool sweep pump.
Those pumps are dual voltage...Are you certain you connected it correctly for the voltage present? If the motor is set up for 230V (as it usually is when purchased new) and you only feed it 115 volts it will heat up and then act as you are describing. The side of the motor will have a diagram for how to reconnect the motor if necessary.
If connected correctly you would have a voltage issue in the line to the pump (unlikely). Check the voltage present at the motor terminals under load and look for a drop of more than 10%. If this is the case you will likely need an electrician.
Like I said though, it is usually because of wrong voltage setup for the problem you describe.
Posted on Dec 19, 2009
Water comes out of the tail of polaris 360, but tail does not sweep.
check the filter in the wall of the pool where the Polaris line hooks up, it got a small filter in it. you are running it on low-pressure that's why it not sweeping, could also be a plugged impeller on the booster pump.
Jay the pool pump motor repair guy Longwood Florida
Jun 21, 2017 | Polaris Pool & Spa
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Polaris booster pump runs for minute but quits. Tries to restart
Aug 24, 2009 | Polaris Pb4 - 60 Booster Pump
POLARIS PB-4 3/4 HP BOOSTER PUMP -- body of pump very hot, too hot to hold hand on. 20 amp breaker gets very hot also. Has not tripped the 20 amp breaker yet.
Jun 08, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
55 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
