Question about Air Tools & Compressors
Df 5020 devilbiss
Belt is broken looks like the pully on the compressor has a gash on the side of it don't know if that would chew up the belt and it is a groved belt
3 Suggested Answers
  • 60 Answers
SOURCE: Timing Belt replacement for a Craftsman air compressor
you just replace the belt, timing is not nessescary.
Posted on Aug 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Relacing the belt on my cplc 7060v compressor it
hi kbarna12776.
To align the two pulley to prevent "walk off" use a straight edge tool and square to make sure the two pulleys are in alinement.
You will start by putting the straight edge tool against the two pulleys and check the straight alignment, and the square.
You will normally adjust the motor to square the pulleys.
The compressor and its pulley stays locked in place.
You may have to use metal spacers under the motor to acheive this alignment.
The proper belt tension on the belt will be when you tighten the belt to where when you push down on the belt with one of your fingers or your thumb and you can only deflect the belt approx. 3/4 inch.
When you have the motor and pulleys aligned and the belt adjusted you will be good to go.
Please take time to rate me highly
Posted on Aug 31, 2011
Hi, I have a DeVilbiss air compressor Model No. IRL 5020 5 HP 20 gal reservoir twin cylinder and would like to obtain a service manual. Thanks Gerry
you can try their website . many companies do not sell or give service manuals out except to their repair site people . it is called JOB SeCURITY
Jul 16, 2016 | DeVilbiss Air Tools & Compressors
Dixon 5020 mowerhow do i install drive belt on 5020 dixon
If, and I'm sure it is, like all other riders, remove the deck, turn the mower up on it's side and supported with a lawn chair or the like, it won't hurt the mower, remove the electric deck drive unit from the crankshaft by taking the center bolt out and pull it off, remove the clutch tensioner far enough to get the belt off it, then remove the belt from the motor pully and the hydrostat drive pully and pull the belt out towards the front. replace the belt with new one and put it back together.
Oct 15, 2014 | Garden
How do I put the drive belt back on my yard man automatic riding lawn mower?
The v side of the belt goes in the v of the pullies and the flat side of the belt rides on the flat pullies. It looks like the flat idle pully is bent out of alinement. The one showing in video with no belt on it that is the last pully the belt runs on before returning to engine. The belt comes from the engine to a spring loaded flat pully, to v pully on right of mower ,to v pully on left, to flat idle pully // that looks to be bent // then back to engine. Put belt on all pullies saving the spring loaded pully for last.
Apr 09, 2013 | Garden
The pully on the compressor is bad can i just leave off the compressor and bypass it with a different size belt
Yes. there are basically three ways:
1. Put in a new a/c compressor.
2. Try a smaller serpentine belt. If this model came also w/o a/c, that serpentine belt should work fine. If all Santa Fes came with a/c then like you were saying try a smaller belt. You might have to try different smaller belt sizes(as far as I know) until you really get it right, which is not easy.
3. See if they make an a/c compressor delete pully for your particular model. This is basically just a single standalone pully (dummy pully). Aftermarket companies do not make them for all models, but if they make it for yours, you can use the same serpentine belt w/o a compressor. The internet is the best place to check.
Sep 20, 2011 | 2002 Hyundai Santa Fe
Serpentine belt diagram
the main digram for all drive belt ( flat belt ) is . first look to all pully make drowing out side with small paper 3 or 4 or 5 or 6 .....pully the main drive pully is crank . the end of you belt round the pully must be more than 180?? angl. alternator angl. more than 180 .compressor or water pump anther pully try use same digram .guide pully and belt tensioner no need to put angl .
Jun 25, 2011 | 2005 Ford Focus
Where do I loosen my belt that is runs A/C on 2000 Toyota Sienna?
One of those "wheels" or TENSIONER PULLYS on your vehicle is the tensioner for the a/c compressor. You will need to look at it and see if there is an adjustment bolt behind pully. If there is, loosen center pully nut, then run adjustment bolt out to slack out the belt. Replace belt and reverse prosedure. DO NOT OVERTIGHTEN BELT,as you can damage pullys and or belt. Tighten to factory specs. Rule of thumb is pulling the belt out and check for slack. No more/less than one inch slack.
Jul 23, 2009 | 2000 Toyota Sienna
Cant put on belt right
from front of engine looking back,belt around bottom of crank pully,water pump is just above,left side of belt comes around water pump going counter clock wise,put belt over alternator,then straight across to a/c compressor,(make sure belt goes under any idler pullies,smooth side of belt to smooth side of pully)find your belt tensioner,pry back on tensioner(be carefull)and carefully place belt under roller pully of the tensioner,release and check allignment of belt prior to starting.oh ya make sure belt is in good condition.
Mar 01, 2009 | 1991 Chevrolet C1500
Serpentine belt came off need to know how it goes back on
this is hard to exsplain without showing you a photo ,but i will try. first get the belt around the engine crankshaft which is the pully closest to the bottom and center of the engine. when standing in front of engine start to lead the belt to the right and connect to power steering pump then up to generator, next thare is going to be a smooth pully not groved like the others to the left,put the smooth side of the belt on bottom of this pully and continue left to the ac/compressor go around ac/compressor andstraight down to the belt tensioner , and then right over to the water pump which has a smooth pully not grooved. remember the smooth pullys will always carry the smooth side of the belt and the grooved pullys the grooved side of belt. the belt tensioner will half to be released by a serpantine belt tensioner tool sold at your local auto parts store. these instructions is for 3.8 liter engine, if you have a 4.6 liter engine it will be different, so repost stating that you have a 4.6 if this dont help
Dec 22, 2008 | 1997 Mercury Cougar XR7
Surpentine belt.
depends on which v8 you have....the 4.7 the routing is as follows it goes under the waterpump pully over the alternator down and around the power steering pumpto the crank...it goes under the bottom of the crank to the idler pully.the flat side of the belt goes ver the idler then around the automatic tensioner to the ac compressor.
on the 5.2 and 5.9 it routes starting at the idler pully the flat side goes undr the idler the up to the ac compressor around the compressor and down to the power steering pump ... around power stering pump to waterpump where the flat side is against waterpump pully around water pump down and around crank up it automatic tensioner....around tensioner and up and over alternator
Nov 30, 2008 | 2000 Dodge Durango
The serpentine belt on this rodeo continues to fray. it appears that the belt rides to close to the inside (motor side ) of the water pump and cooling fan pulley. The air conditioner has been replaced and...
I can probably help you both. Check your powersteering pump. There is a bracket that connects it to the exhaust manifold. My braket broke and the pump adjusted forwards which allowed the belt to get chewed on. I can also help with the routing of the belt. If you have AC and power steering it travels this way, ( I can also give a picture with an email address). Put the belt in through the passenger side by the battery and loop it over the crank pully, now bring it around the water pump so that the inside of the belt is on the crank and the back of the belt is on the water pully, then it goes around the power steering and up to the AC, there is an idler pully between the altenator and the AC compressor, the belt goes under it, then over the altenator, lastly you'll need a 15 MM socket and will have to pull the tensioner to the driverside by pulling to the passenger side and puttin the belt on the outside, Use a long bar and watch that top radiator hose and the fan blades. Its a bit of a pain, but I've had to take my belt on and off so many times I don't have to look at the pictures. Plus the pictures are drawn sideways to the engine. If I'm feeling frisky I'll draw it on paint and post a link for it.
Aug 12, 2008 | 1991 Isuzu Rodeo
Air Tools & Compressors Logo
22 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
