On my boiler there is a honeywell l4006e aquastat and a honeywell l4081a dual aquastat. when it calls for the boiler to ignite i have to press the reset button on the l4006e what could be tripping it?
5 Suggested Answers
mohammed387
  • 1952 Answers
SOURCE: I have installed honeywell aquastat
it ll operate only wen it gets fault current in main supply..can u tell how come u know tat it is workin?
Posted on Sep 13, 2008
  • 234 Answers
SOURCE: what would the correct high and lo and diff
I would say high if you need cooling. If the tempature is cool enough for you then set it to low.If you are hot and need more cooling then high.
Posted on Apr 07, 2009
refixed2
  • 23 Answers
SOURCE: i have a weil-mclain boiler.i
could possibly have a faulty heat anticipator setting on the stat, causing an over run on heat anticipation., or a stuck zone valve on one of the distribution sectorts,,,,,rad, infloor loop ect ect
Posted on Oct 26, 2011
shastalaker7
  • 1515 Answers
SOURCE: why does the reset button on the aquastat keep tripping every time boiler finished a cicle
Hi, this is because the boiler aquastat is faulty! Change it out as the contacts are worn out causing it to trip the stat. I have seen this so many times. Please let me know.
Shastalaker7
A/C & Heating Contractor
Posted on Apr 09, 2012
Where do i adjust boiler temp on a gas fired boiler
difficult to say just where the temperature control is on your system. it will likely be an immersion type control located some on or near the boiler. it should have a temperature range scale on it.
Jan 25, 2013 | Heating & Cooling
Looking for simple wiring diagram to wire ******** aquastat
What are you fanning??? the fire?
Do you have a circulator that circulates when the water is up? Many controls have a AUX connection ... wire the AUX to your fan --- alaternatively, wire directly fron your circulator connection to the fan.
I hope I understood your question ...
Let me know what happens.
a
Oct 16, 2009 | Honeywell International Honeywell&...
What would the correct high and lo and diff settings for the Honeywell L8124A Aquastat I have a wood fired boiler with the oil fired boiler side by sides,
Apr 05, 2009 | Honeywell Heating & Cooling
I want to increase the boiler temp by using the your aquastat
Warning! Can cause electrical shock! Here is the instruction manual
for L7248c
http://customer.honeywell.com/techlit/pdf/PackedLit/68-0281.pdf
Jan 12, 2009 | Water Heaters
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
SYMPTOMS: BOILER SEEMS TO IGNITE AND FIRE UP EVEN WITH BOTH THE HEATING AND HOT WATER OFF. DO YOU THINK IT IS A BYPASS VALVE ADJUSTMENT PROBLEM? I HAVE A DU145, HOW DO I ADJUST IT? HARISH LATHIA
Some boilers must maintain temperature for proper operation. Not sure what a DU145 is?! Give us a brand name and a model number and any additional information you can such as thermostat setting, Aquastat setting (if you can) etc...
Jun 08, 2008 | Honeywell Heating & Cooling
Boiler will not shut off
boiler does not shut off when thermostat reaches temp, i already replaced aquastat but condition still exists
Nov 14, 2007 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
