What is the default user name and password for greenpacket router dv-235
Trying to log into the modem to change my default password but doesn't work when i use the admin admin for username and password neither does root and admin ...can some one suggest any other option . thanks
  • 556 Answers
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Posted on Dec 06, 2007
peglegcards
  • 89 Answers
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Posted on Mar 27, 2008
SOURCE: DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
Posted on Jun 08, 2009
jeevan.m
  • 392 Answers
SOURCE: default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Posted on Jun 22, 2009
  • 89 Answers
SOURCE: i cant log into the admin account on 192.168.1.1
press the RESET button on the back of the router and hold it in for 30 seconds. Use a pin. Once you have reset the router it will default to a generic user name and password. The default user and passords are admin admin or user user
If you still have trouble call support
Telephone (North America) 877-ZHONE20
Posted on Aug 03, 2009
Don't the user name or password for my motorola SB900 can you help ?
That's depends...First, do you have the password to log into the modem? it seems that the default is admin/motorola. If that hasn't been changed, you could log in and remove the WEP key.
In addition, most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't be worry...Or if these all can not work, you can call or ask directly to the customer service of Most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't worry... or if the above ones all didn't work, you can call or ask the Motorola customer service directly, maybe they know the solutions because they produce it!
May 30, 2012 | Computers & Internet
I have a netgear router, which needs booting but i am away from home and cannot do this, is there a way that it can be rebooted.
1.Log in to the modem router at its default LAN address of http://192.168.0.1 with its default
User Name of admin, default password of password, or using whatever User Name,
Password and LAN address you have changed and chosen for the modem router.
2. The ADSL Modem Wireless Router has a diagnostics feature. You can use the diagnostics menu to Reboot the modem router.
3.From the Main Menu of the browser interface, under the Maintenance heading, select the Modem
Router Diagnostics heading to display the menu shown.
4. The modem router will then reboot automatically
NetGear DG834G Manual You may refer to the Router's Manual Page 5-15
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 15, 2011 | NetGear DG834G Router
Lost password
By default there is no user name and paswor. So try leaving the user name and password blank. If it doesn't work, reset the router. There should be a reset pinhole or button to bring the router to it's factory settings. After resetting the router, try the default user name and password again.
May 21, 2011 | Proxim SkyLine Wireless Broadband Gateway...
Want to change user name and pass word
You can do so by opening the GUI page of the router:
First connect it to the computer through a Ethernet wire and then check the default gateway (go to command prompt and type ipconfig)
put in the default gateway address in the internet explorer address bar
Log in to GUI..the default username and password is following
Username: admin
Password: admin
or
Username: admin
Password: password
Log in and change the username and pasword...you would also be able to change the wireless password (WEP key) from same
Sep 25, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
Aug 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Not able to install the software, tells me mdm.exe has stopped working and won't go any farther
Manual Setup: This option is best if you cannot use the wizard on the CD, are replacing an
existing router, or are technically knowledgeable. Follow the instructions in this manual to set
up your router.
Connecting Your Router
1. Connect the router, the computer, and the modem.
a. Turn off your computer.
b. Turn off and unplug the cable or ADSL broadband modem.
c. Locate the Ethernet cable (1) that connects your computer to the modem.
d. Disconnect the cable at the modem end only (2).
e. Securely insert the free end of the cable (1) into a LAN port on the router, such as LAN
port 4 (3).
f. Securely insert the yellow cable (5) that came with your router into the yellow Internet
port of the router (4) and the other end into the modem (2).
Setting Up Your Router for Internet Access
To access the router using its login name and password, follow these instructions.
1. Connect to the router by typing http://www.routerlogin.net in the address field of your
browser, then click Enter.
For security reasons, the router has its own user name and password. When prompted, enter
admin for the router user name and password for the router password, both in lower case
letters.
Enter the user name and password. The router will display its home page.
When the router is connected to the Internet, click the Knowledge Base or the Documentation link
under the Web Support menu to view support information or the documentation for the router.
If you do not click Logout, the router will wait 5 minutes after there is no activity before it
automatically logs you out.
Set Up and Test Basic Wireless Connectivity
Follow the instructions below to set up and test basic wireless connectivity. Once you have
established basic wireless connectivity, you can enable security settings appropriate to your needs.
1. Log in to the router at its default LAN address of http://www.routerlogin.net with its default
user name of admin and default password of password, or using whatever LAN address and
password you have set up.
2. Click the Wireless Settings link in the main menu of the router.
3. Note that the default SSID is NETGEAR.
4. Set the Region. Select the region in which the wireless interface will operate.
5. Click Apply to save your changes.
6. Configure and test your computers for wireless connectivity.
Program the wireless adapter of your computers to have the same wireless network name
(SSID) as the router. Check that they have a wireless link and are able to obtain an IP address
by DHCP from the router.
Note:
Apr 19, 2009 | Computers & Internet
Rest password on DNA-A211-I ADSL2+ Modem
hi..
the only way to restore the router is to hard reset the router,which will reset the router to the factory defaults and then setup the router as the first time installation and the default username and password will be restored,i kno this is much of a work to reset the router and again setup the router like 1st time installation but this is the only way to retrieve the default user name and password..
vedhick
Jan 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Comtrend ADSL2+ Router CT-5621T
there's quite serious security problem with this routers (not sure if it applies to exactly this type)
if your password if not the default you should try other account:
(username / password)
admin / admin
support / support
user / user
if you are logged in as a "user" you can't change anything but you can access change password page e.g.
http://192.168.1.1/password.html
then open source code of this page and inside javascript code you will find your password in plain text
<!-- hide
pwdAdmin = 'admin';
pwdSupport = 'support';
pwdUser = 'user';
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
