Question about Troy-Bilt Garden
Troy bilt model 020245 psi washer 4.5 hp briggs/ no spark
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
  • 436 Answers
SOURCE: I have lost manual to
Here is the link
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=hqktGGuVh.IjhJvcv4
Hope it helps
Thanks
Please rate FIXYA
Posted on May 20, 2011
Need an engine manual for Troy bilt pressure washer 2200 max psi model 020245
find the make of engine on the washer and if possible the model of the engine
go google and type in ---workshop manual for ( make and model of engine)- surf the pages and fins a pdf down load for that engine
Feb 02, 2016 | Psi Garden
How do I stop gasoline?
Float and/or needle valve and seat need to be repaired/replaced.
Nov 08, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
How do I change oil in my Troy Bilt Model 020245 pressure washer
if its a vertical engine it;s underneath the base of motor look for a plug with a square slot in it i usually use a 3/8 " extension
Aug 21, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pump
if it,s a vertical motor it's at the base of motor look for a plug with a square slot.
Oil for a troy bilt 2550 psi pressure washer pump
May 17, 2009 | Briggs & Stratton Garden
Garden Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
