PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Hp pavilion dv6000 does not turn on
By tauras on Oct 07, 2007
hello my hp does not turn on when i press power button it seems like it begins to start all lights turn on i hear cooler but then it just turns off and then starts again i don't even see hp logo sometimes it starts up to the point where i can enter the bios but it cannot boot from hard drive because it cant find it. sometimes very rarely it boots to windows and goes without problems until i reboot or switch it off.
Clarification Request
Posted by suechan28 on Feb 19, 2008
zedmanauk's information sounds helpful but is only "available in North America for 24 months" (those of us in the rest of the world often have to deal with this situation).
My lap-top, supposedly fixed with completely new hardware, has again gone to blue-screen, restarted etc. I have needed to re-download and install all the upgrades, which in Australia means paying for the extra bandwidth that requires.
My 'solution' for the moment is to stay late at work and use the computer here! I will probably end up with a new non-HP lap-top.
Same Problem
Apr 07, 2009
-   i took off the memmorey card and fixed it back and i turn on the computer it make some noies so i switch off the plug 2/3 time and i can't still turn on my computer please help me to fix this trouble.thank you.-   shanthi2522
Feb 18, 2009
-   I had the same problem. Mine wouldn't start up but all the lights came on & you could hear the fan kicking in for a second. I have no idea what i did but i took it off charge. Took out the battery. Turned off the wirless and let it sit for 10 minutes. I put the battery back in after then & it came on straight away -   Guest
Feb 17, 2009
-   I have the same problem - first started with no internal speaker sound. now won't boot but will start quickplay - talking to hp they said to restore the drive as the os seems like its corrupted!!
We'll see how I get on
-   gwlad1999
Jan 31, 2009
-   same laptop, same problem. power button dead. can only start usng quickplay but cannot get to windows. when i click on the windows button system goes into hibernates.
i was able to get past the quickplay once by pounding the keyboard but dont know how i did it. it ran for 3 months and was never shut off, only put to sleep. unfortunately the computer was unplugged & battery drained and have not been able to start it again.
anyone lucky enough to know how to get past the quickplay start up into windows??-   go2self
Dec 27, 2008
-   I dont know how to fix this.. the laptop wont even turn on?? -   jap8112
Best Solution
posted on Feb 18, 2008
Very Helpful)
GuardDog
Rank: Apprentice
Rating: 98%, 3 votes
Have you tired running a Hard Drive regenerator program, it fixes any bad sectors on the Hard drive, but usually the computer won't start period if that is the case but still, you never know
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 19, 2008
Helpful)
zedmanauk
Rank: Apprentice
Rating: 90%, 16 votes
This is apparently a common problem for HP dv6000/dv9000 laptops. HP has extended the warranty on these models for this problem. See this page:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&dlc=en&lc=en&cc=ca
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #3
posted on Jul 10, 2009
Very Helpful)
pontelemon
Rank: Wiz
Rating: 83%, 214 votes
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have sound in the headphones, but not in the speakers, - common problem with defective ribbon cable underneath the keyboard. We replace tons of them you can buy them on Ebay. We buy it from 2fix.net/flex-fcs.htm cause they are best quality, compeer to Ebay stuff, and shipped from Chicago, not China/Honk-Kong.
Was this helpful?
Yes
No
Solution #4
posted on Jun 10, 2009
Very Helpful)
chaotic_soul
Rank: Apprentice
Rating: 100%, 1 votes
well guys my problem started by one side of the speakers not woking, then they both went dead, soon after the power light went off and then i was unable to start it not even with the quickplay button because it would just hibernate. it is not a faulty os nor is it any sort of software problem. its the fact that the hp customer service is not good at all and their ability to use good computers parts does not exist. so... if u want to use my solution first u have to make sure u have the same problem... try with all ur might pushing down the power button without hitting the quickplay button and see if that will get ur laptop on. then, try applying pressure above the power button and the area around it see if u can get it to turn the light on, if u can then all u have to do is unplugg the ribbon like cable, clean out the connectors and plug it back in. hope it helps.
Was this helpful?
Yes
No
Solution #5
posted on Apr 01, 2009
Very Helpful)
johnnyiroc
Rank: Apprentice
Rating: 100%, 4 votes
The problem is the ribbon cable to the power switch is bad, sound goes thru same cable. Look for a new cable on ebay. That fixed mine. It turns on and has sound now.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #6
posted on Oct 08, 2008
Very Helpful)
dibekallc
Rank: Apprentice
Rating: 100%, 2 votes
zedmanauk is right. Just call to the number that they have over there, they'll send you a box to ship it and in 14 days you'll have your laptop like new
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how loose the keyboard, some of the keys stick!!
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
webcam not working software says it maybe disabled how do I enable
Answer
Good Afternoon I have an ACER Aspire 3100 and for some time now it hasnt been starting up properly... (More)
Answer
I reverted back to Win XP and had to disable the SATA settings in the Bios to do so. I think the... (More)
13 Other Users Have The Same Problem - Continued
Comment by flyboysmb, posted on Dec 27, 2008
We have the DV6000 RK654AV. Pressing the power button & quick play buttons result in the same thing. The lights turn on (including the USB mouse, for a second or two, but then they go off. Sometimes I can mess with the quick play buttons & get the lights to stay on & then I hear a little life from "inside" but nothing. This is about 1.5 to 2 years old.
Comment by Guest, posted on Dec 18, 2008
I have the same problem. Power button wont work. Can start PC through QuickPlay button but when I try to go to Windows, PC hibernates.
Comment by Guest, posted on Nov 22, 2008
I have this problem as well. Unfortunately, the problem with my HP is that the power button does not depress fully. I called HP support and though my laptop qualifies under the extended warrenty, the power button is not covered so they cannot help me unless I pay an extra charge. When I start the laptop with the Quickplay button, there is no way to get to windows besides hibernating.
I am putting money away for a macbook.
Comment by billvg101, posted on Oct 29, 2008
My laptop does the same thing. The power button does nothing (I turn it on and off using the "quick play" button) and the laptop speakers (Altec Lansing) do not work. External speakers connected through the headphone jack work fine.
Comment by node, posted on Sep 07, 2008
I have a hp dv6000 series. But when i press the power button - does not boot!. It started with the internal speakers having problems but at the same time starting it needed some hard press on the power button, I was unable to turn off the pc from the button.
Now, I opened the top cover having speakers and quickplay lights, tried to fix the power cables by exchanging them in some way, but now the PC is totally silent wont start. Does these two cables under the k-board have something in common, as in when one is not connected the other is dead? Please help, some ideas on the trick will be much appreciated? Thanks
Comment by Guest, posted on Aug 06, 2008
is the hp a lemon
Comment by suechan28, posted on Jan 09, 2008
I had the same problem (the laptop is about 6 months old) - the buttons flash but switch off again, then the computer can't start up. The volume light flashes red while all the other lights are blue. I went through MANY steps wit HP helpdesk (email and phone) to try to get it fixed; finally they put me in contact with a real person. He replaced a couple of parts, but the same thing happened, so he took it again to work on it - said the whole inside of the computer was now new; ie there should be no more problems. It is now only a few weeks later and the volume light is flashing red on start-up again and the laptop is making those same noises. So far it is still working but I am wondering for how long.
Comment by zedmanauk, posted on Dec 18, 2007
Same problem here
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
