Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
P/N130202 giagni fresco kitchen faucet is dripping
P/n 130202 giagni kichen faucet drips when faucet is turned off
  • 659 Answers
SOURCE: dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Posted on Mar 16, 2009
  • 21 Answers
SOURCE: My Moen Caldwell 87888 continues to run and drip
This sounds like there might be some dust in the cartridge have you pulled the cartridge and looked for dust.
Posted on Jun 21, 2009
  • 145 Answers
SOURCE: Hi Guys, We had problems with our kitchen faucet
hey has to just reset the handle ok
Posted on Jan 10, 2010
motor1258
  • 6674 Answers
SOURCE: We have a Moen 87315C kitchen faucet and it is
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
Posted on Apr 13, 2010
Dplumber
  • 119 Answers
SOURCE: On new Moen shower faucet,
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Posted on Sep 08, 2010
How do you remove the water restrictor from a GIAGNI Kitchen Faucet, Fresco Model PD180-SS?
If this is a kitch faucet with the spout/sprayer combo, then there are two possible locations. One location is at the ends of the supply tubes with 1/2" npt threaded ends where they connect to the flex supplies from your two valves under the sink. Turn the water off and disconnect the supply nuts. The flo-checks can often be removed using needlenose pliers.
The other possible location is at the spout itself, but this type may not be removable without damaging the seal to the aerator. Remove the aerator, and there is probably a light spring in there. If you remove the flo-check from beneath the spring, tha aerator may not seat properly and will leak. Good luck.
Mar 17, 2017 | Plumbing
Our Giagni Andanti model LL800-BN bathroom faucet drips after water is turned off need to know how to make an adjustment to stop drip
Turn the water off. Remove the handle, usually has an Allan wrench screw on it. Take out the stopper unit and clean it. When you are done tighten it as you can without stripping it, Out it all back together and it should work. Sometimes you need to replace the washers or internal unit itself, but try this first.
Apr 16, 2014 | Giagni LL800 Andante Open Trough 1-Handle...
Fix a dripping single handel moen faucet
you can go on line with the make
Nov 11, 2013 | Moen Plumbing
Leaky kitchen faucet
What kind of faucet? (single handle, double hndle, kitchen, bathroom) Where is it dripping from? (handle, aerator or faucet head, under the sink) There are many types of faucets and many types of leaks. Sorry to be so vague but there's a pretty wide spectrum of possibilities, a little more info will go long way.
Feb 04, 2013 | Plumbing
Ii need install instructions for Giagni Kitchen Pro Series Model KP50-PC
Faucet discontinued but:
Install pdf on Overstock.com listing for KP50.
Also, Giagni 888-560-5222
Aug 19, 2010 | Plumbing
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
Jun 30, 2010 | Delta Model 470: Signature Kitchen...
I had a dripping Kohler Finial kitchen faucet
Any bit of dirt or grit in the line will get caught in the cartridge if not flushed properly.
Apr 18, 2010 | Kohler K-16109-4-CP Revival Kitchen Sink...
Danze faucet and soap dipenser drip
it could just be a defective unit,it is not unheard of.i have run into this myself alot of times.if you can take it back and get another unit.
Jul 08, 2009 | Plumbing
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
53 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
