Question about Panasonic NN-S540BF Microwave Oven
No cook mode
Micowave starts after intering time,but shuts off in a couple of seconds
  • 5 more comments
  • spirokahn Nov 24, 2007
    We can enter the cook time, but after pressing start, we don't hear the fan, or see the glass plate rotating, indicating that it is actually not able to heat. The clock counts down about two seconds, but then gives up, as nothing is actually happening.
  • wondagirl Nov 29, 2007
    My microwave only works for 5 seconds and stops. The clock works, timer works, and the child lock works. So not sure what the problem is cus I've powered down for a while, Nothing. This actually happened on Nov 24, 07.
  • Lindag1 Dec 19, 2007
    I think I have an older model, NN S542BF. It shuts off after 38 seconds, on the nose and it doesn't appear that it's heating. What the average lifetime of a microwave.
  • clarky84 Sep 23, 2008
    microwave shuts off after just three seconds after start.
  • sfkeatley Jan 14, 2009
    My microwave oven NN-S540BFWR was manufactured in January 2003. Today, Jan. 13, 2009, it has this problem: It will run for three seconds and then shut down. Everything else on the unit is working properly. Could you let me know if this is a fixable problem, or has the unit reached the end of it's lifecycle? sfkeatley@cox.net
  • Anonymous Mar 14, 2014
    when we go to cook food it will run for about 2 seconds than shut off and ask us to enter the time, date
  • Anonymous Mar 15, 2014
    after cooking food for 2 seconds it shuts off and askes us to enter the time and date.
    Champion:
  • 225 Answers
Check control circuit, and check highvoltage section, and all the door lock switches, and sensors, chaeck over all circuit..
Posted on Oct 09, 2007
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
Ge microwave overhead 2004 model start it up and it will run for 2 seconds and it shut down have to reset time date ect,ect and it might work next time or you may have to wait till the next day before it...
There are a couple of safety thermostats under the cover that can shut down power. One is on the magnetron tube (the microwave source) in case the tube overheats. Another one is on the cooking cavity to shut the oven off if something catches fire while cooking. These interrupt the power, same as unplugging the oven, which is why you need to reset everything.
It's possible that because of the oven's age, the magnetron tube is weak enough that it's overheating when it tries cooking. As the tube ages it works harder and gets hotter. But it usually takes more than a couple of seconds for the thermostat to operate. These thermostats sometimes go bad on their own and operate too soon.
Other possible causes for power loss are a fuse loose in its holder or intermittent connections to the control circuit board.
Since troubleshooting power problems means working on the oven with the cover off and the power on, you should leave repairs to a professional. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. Let a professional check the oven and give an estimate for the repair. Given the age of the oven you may want to consider replacing rather than repairing this one, but let cost be your guide.
Jul 09, 2011 | GE Microwave Ovens
Will not cook or will not warm
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Jul 24, 2009 | Panasonic NN-H504WF Microwave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Panasonic Inverter Micowave only runs for four seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 24, 2008 | Microwave Ovens
R957 cooks for 59 seconds then stops ,resumes for 59 seconds if cook /start pressed all cooking modes affected kitchen timer works ok
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 31, 2008 | Microwave Ovens
Will shut off in all modes after 59 seconds. will keep countdown time when shuts off, restart and will start and continue count down time for another 59 sec only. voltage good. unpluged repluged. makes no...
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | Sharp Microwave Ovens
Lights up BUT does not cook
was there any motor that should run as you turn it on, the fan inside and the rotating table motor. try to replace that micro switch at the door that bubbled out and burnt. try to test or replaced right away the industrial diode that is connected from the capacitor to the ground of the microwave.
Feb 17, 2008 | Panasonic NN-S763BF Microwave Oven
Panasonic NN-S540BF Microwave Oven Logo
245 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
