Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
Pro tech 7207 compound miter saw is stuck closed
5 Suggested Answers
SOURCE: makita ls1013fl I need instructions on how to install
I installed it by looking at the parts pictures in the manual and experimenting. Thanks for the try at helping me.
Joe
Posted on Dec 15, 2008
SOURCE: makita LS1013 compound saw wont slide,instruction
You may find, you have a lock, button, that needs to be held in, before you can drop the saw to cut.
Posted on Apr 28, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a Makita LS
check position 79 the spring that pushes against the table and also the end of the locking knob to make sure not rounded over/worn not applying pressure to the locking spring.
Posted on Dec 22, 2010
stug_57u
  • 99 Answers
SOURCE: change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Posted on Jul 23, 2012
Skil Compound Miter Saw laser quit working, Help
SKIL 10" Compound Miter Saw 3317-01
www.skiltools.com/Tools/Pages/ProductDetail.aspx?model=3317-01 Skil10 In. Compound Miter Saw with Quick Mount System and Laser Cutline. Model #3317-01 ... manual Get Manual (PDF); parts list Get Parts List (PDF) ...
[PDF]Operator's Manual 10 in. COMPOUND MITER SAW WITH ...
c.shld.net/assets/own/00921236e.pdf
Dec 14, 2015 | Skil Saws
Product just arrived, saw is stuck in cutting position
There is usually a safety or transit lock or pin which is engaged to lock the saw down for safety and for a more convenient way or transporting it.
The ones on my saws are a simple ball-headed pin sited close to the hinge of the saw which can be easily withdrawn once enough downward pressure has been applied to the saw to overcome the return spring pressure.
Mar 15, 2015 | Dewalt DW713 NA 10" Compound Miter Saw
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
The motor brake on my pro tech miter saw doesn't function. Is there a doable fix ? Also need an owner's manual
The brake on saws like yours are controlled by the switch. They do go bad and are easily replaced if the parts are still available. Your heading says you have a Makita tool but you didn't give the model number. If you go to the Makita home site at:
www.makitatools.com/en-us/Modules/Home/Default.aspx
you can put your model number in the search box and get a parts breakdown and owner's manual if they are still available. Parts are available online at sites like www.ereplacementparts.com where you can also get a parts breakdown but not manuals.
Jun 06, 2012 | Makita 10" Dual Bevel Sliding Compound...
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
My LS1216 slide compound miter saws mitering table is stuck at 0 degrees it appears jammed although I've looked for something jammed stopping the plate from moving and see nothing, the handle locking...
Hello stella....... There is a locking mechanism on the miter saw to lock it on whatever setting you require. loosen that locking mechanism and the saw should move for you. Here is a schematic of the parts so you can see exactly which parts are involved
http://www.searspartsdirect.com/partsdirect/part-model/Makita-Parts/Saw-Parts/Model-LS1220/1339/0744300/P8100100/00002?blt=06&prst=&shdMod=
Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Makita 10" Dual Bevel Sliding Compound...
Where can i get a left handed thread bolt for a 7207 pro tech compound miter saw
I would recommend looking in the phone book under tools, electric and find a repair shop close to you that would have one. What area are you in and I can also try and find a shop online that might be able to help. I don't think that there is anything special in the LH bolts for the mitre saws. Let me know and I will do what I can
Jun 06, 2009 | Pro Series Saws
Craftman miter saw
should be located at the pivot arm assy where close to the motor.
Mar 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
198 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
