Question about Sharper Image Super Wave Oven Accessories
Replacement parts Where can I find replacement pieces, racks, pans for super wave oven?
Where can I download a Owners Manual
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0CEMQFjAG&url=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2FA1T226kZkES.pdf&ei=UVzKVJW_HeTY7AaB9YGwCQ&usg=AFQjCNGunI_0JtjH_k9H-uEkhB5T6hIpsA&sig2=wmpvkWusFFJY-dl0Us7ebA&bvm=bv.84607526,d.ZGU&cad=rja
Aug 16, 2014 | Sharper Image Super Wave Oven Red
I plugged in in for the first time after unpacking it and my super wave oven will not heat
Ship it back and get a replacement, don't forget to get an RMA number from sharper image.
Oct 27, 2013 | Sharper Image Super Wave Oven Accessories
The racks all fall out if even the slightest weight is on them, very scary keep waiting to burn myself badly
Hello Kathy Manson - Unfortunately, based on the symptoms you are describing, the oven liner would need to be replaced. The oven liner cannot be adjusted or shimmed to resolve this issue. If I was in your position, I personally recommend consulting an experiencing service technician to assist with the repairs.
Mar 04, 2013 | Electrolux 30" Built-In Single Electric...
Oven not coming on correctly or up to temp setting
The most common problem is a bad oven glowbar ignitor.
The part number is 5303935066.
Remove the oven racks and the oven base pan to access the ignitor for replacement.
Mar 18, 2010 | Frigidaire Ovens
My propane oven takes 10 min. to light
The ignitor has gotten weak. Replace the ignitor.
Turn off the power,turn off the gas supply.
Remove the oven racks.
Remove the oven base pan.
Remove the flame spreader.
Remove the ignitor and replace it.
Jan 15, 2010 | Ovens
Hello when i put my temp for my gas stove on say 350, the pilot is glowing but it doesnt seem to flame/heat up, and i get a somewhat odor of gas, could the therometer need replacing or maybe the ignition...
Your glowbar ignitor part must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
Copy and paste this site for the location of the ignitor you can also purchase the part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111359&diagram_id=362260#d362260
Jan 01, 2010 | Frigidaire FGB24T3A Gas Single Oven
Started oven to bske brownies - started beeping and the letters F-3 came up?
F3 is a bad temperature sensor.
Unplug the range. Remove the oven racks. Look up high in the rear portion of the range oven for a thin metal piece about 4 inches long. Remove the screws and remove the temperature sensor for replacement.
Parts can be found at repairclinic. com .
Enter your model number found inside the pan drawer to look up the temperature sensor.
Dec 31, 2009 | Maytag Ovens
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Sharper Image Super Wave Oven Accessories Logo
49 people viewed this question
Top Sharp Ovens Experts
JOHN LAPIER
Are you a Sharp Oven Expert? Answer questions, earn points and help others
