When you turn the TV on after about 3-5 minutes it starts to release a shrilling sound and the screen turn neon green and yellow with vertical lines that looks like xmas wrapping paper.
LCD HDTV 232T 2 years old?
  • Televison & ... Master
  • 2,005 Answers
Replace the power supply
Posted on Nov 18, 2013
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Posted on Aug 21, 2008
  • 10 Answers
chake to make sure it is hooked up right and not lose
Posted on Feb 02, 2009
  • 98 Answers
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Posted on Feb 06, 2009
  • 53 Answers
SOURCE: vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Bad/Going Bad/Will go horribly bad TCON board (small circuit board sitting at the top of the panel in the back).
Most likely, the whole panel will need to be replaced in order to rectify the issue.
Posted on Aug 01, 2009
SOURCE: 3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Posted on Jan 21, 2010
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Green and purple vertical stripes on our TV screen
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
Sep 14, 2007 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
