Question about Frigidaire Washing Machines
Washer will not spin or drain water
Electrolux combo
    Problem Solver:
  • 14 Answers
Sounds like the belt has come off the back,or if it used to make a lot off noise and jumping before it stopped working then its likely that it needs new brushes
Posted on Nov 18, 2013
kjmac
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
SOURCE: water does not drain out from my washer
I have determined one of the reasons ( I feel this is the primary reason) why many BOSCH washing machines will not drain the water, Bosch uses the same drain pump in many of their 500-800 series washing machines, part number 436440. The drain pump is a electrical controlled magnetic driven pump. Simply a electrical current produces an electrical field which a magnet rotates, spinning the pump blades. I have determined that the internal seal on the pump part is allowing water to leak into the magnet area of the pump. This is causing corrosion, and water build up around the magnet, interfering with the magnetic field. How I came to this conclusion. After removing the end of the pump, and allowing the water to drain out, drying out the pump, the pump will work as advertised. But of course the pump cannot be used in this condition. A new pump is required. To determine this yourself, if the machine is not under warranty (good luck getting service). Unplug machine, remove back panel, unplug the drain pump, remove drain pump (separating the drain pump from the large plastic holder, there are three screws holding it to the housing). You can shake the pump, and if water comes out of it this is most likely the problem. Now hook the pump back up to its electrical feed, and place it on a rubber sheet. Set the machine to drain, if the pump attempts to spin then stops, or hums this is the problem.
Posted on Nov 10, 2008
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Posted on Aug 03, 2010
My top load electrolux washer machine, model MEX731CAS3 does not drain. it spins well and the cycle gets completed except the draining and centrifuging part. any suggestion?
The function of the pressure switch in the machine that gives a signal if the washing machine is full or empty with water.Spining cycle will start only if the machine is previously drain water and pressure switch overlapped to the empty position. Check everything about pressure switch and hydraulic circuit (tube and pressure chamber).
Dado
Jun 25, 2015 | Electrolux Washing Machines
I have an electrolux EIFLW55HIWO washer. When I wash clothes everything is okay. After emptying the washer it will let water seep back in. I will do the spin cycle and a couple days later the washer has...
Hello friend, thanks for your inquiry!
I see you are experiencing a water issue within your Electrolux washer. It sounds like it could be a problem with your water valve, drain pump, or control board. Since it could be any one of these underlying issues I would recommend having a professional come and diagnose your appliance properly. I hope this helps to some degree. -Matt
Aug 23, 2014 | Electrolux Washing Machines
What is the problem why water does not drain after rinse cycle?
Hello friend, thanks for your post!
I understand that your Electrolux washer is not draining properly. Some possibilities for your washer not draining could be an issue with the drain pump or control panel. You should additionally check the drain hose to make sure there are no restrictions. If your washer continues to not drain properly you should seek assistance from a professional to repair the appliance. I hope this is helpful. -Matt
Aug 12, 2014 | Electrolux Washing Machines
Washer making loud noise willnot spin cycle or drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Electrolux AWF 1435 Front Load Washer
Water wont drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 12, 2011 | Electrolux Washing Machines
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Wsm2480dww laundry center(combo)
The washer drains the water durring the neutral drain. (water drains out but the basket does not spin). Then the timer will hit a "pause" (basically removes the power momentraily so the gear case can change gears). So if you are not getting the pause durring the cycle, lifting the lid does the exact same thing. I would agree with you from your last comments that you do have a timer issue. They can be ordered on line from the manufacture or more readily a local appliance parts store.
Jul 10, 2008 | GE WSM2480DWW Large Capacity Washer & Gas...
Washing Machines Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
