Question about Comfort Zone 12 In Oscillating Table Fan - CZ121
Need a part
Need to find a housing part
    Sergeant:
  • 272 Answers
Usually parts for appliances such as these are not worth replacing. The price may be almost as much as a new fan. Try to fix with epoxy or such, if you are really determined search the web for manufacturers site to get parts information or an appliance parts store and call with model number to see if parts are available.
Posted on Feb 24, 2015
HOW MUCH MONEY DO YOU NEED TO BUY A HOUSE IN GTA V?
If you walk up to the houses in game it will display the price of the house you want to buy. You can also use the in game cell phone and go to the home buying website and it shows all the houses in game that you can buy.
Mar 22, 2015 | The Video Game Consoles & Games
Need a auger housing for a snapper le317
Hello! You may have already gotten your new auger housing, but here is a link for our site where a new auger housing is available! I checked to make sure that this was the correct part for your model!
Snapper AUGER HOUSING ASMY Part 7052968YP
Happy Snow Blowing!
Feb 21, 2015 | Garden
Do i have to remove manifold to change thermostat and thermostst housing. I see a metal pipe gong under manifold which is connected to housing.
no, removing the manifold will still not allow you room and it can not be removed upward it needs to slide out the front so radiator and condensor need to be removed or remove radiator and then try to slide out and up. i can tell this, the pipe part of the housing hardly ever goes bad, the plastic housing is what leaks, if you are trying to replace the housing you can unbolt the pipe and reuse it with out removing it, remove pipe from the new one and just use housing, remove the two bolts and slide pipe off and then same on the car remove the bolts holding housing on and then remove the rear bolts holding pipe on the rear of housing then slide old housing off and install new one. i do this both ways all the time and most of the time all i do is housing, the pipe comes with the housing but i remove and throw out or give to customer, this will save you so much time and pipe is not needed.
Mar 03, 2013 | 2005 Chrysler 300
I bought a Premium Ware style dog house and Do the walls of the house need to be waterproofed? It says shingles and feet are waterproofed
If you are keeping the dog house outside it would be best to waterproof all of it just to be sure.
May 13, 2012 | Dogs
2004 Ford Explorer V6 engine over heating i replaced gasket, thermostat, top housing unit and the o-ring now it is leaking from behind the base where the thermostat housing is bolted down to just behind...
There is a gasket on the base of the housing, the housing you speak off has the sensor and a heater hose and bolts to top of the intake and also hold the thermostant, this housing does contain a rubber molded gaske, i have replaced a few of these, heres the problem i have run into a couple where the plastic was eaten away in the area that holds the gasket in place. if you remove it you will see a groove that the gasket sits inside of, if the groove is broken then replace the housing but if its good then all you need is the gasket, you will need to ask for thermostat housing gasket to engine intake, this gets confusing to a parts person as they may think you are asking for the thermostat gasket, also in the rear bottom of the housing theres a hose connected to the housing make sure thats not your leak, the hose may also be leaking. good day
Sep 03, 2011 | Ford Explorer Cars & Trucks
Information on how to remove oil filter housing
Removing your oil filter housing is a simple task with the correct tools. You will need to evacuate the oil in the drain pan before removing the filter housing. You need a torx bit to remove the housing. The oil filter housing is located near the distributor cap. You can unbolt the housing by unscrewing the torx bolt on the outside of the neck. The filter and the housing will come out.
Read more: Jeep Oil Filter Housing Removal ' eHow.com http://www.ehow.com/way_5649355_jeep-oil-filter-housing-removal.html#ixzz1CS95qEdH
Jan 28, 2011 | 1999 Jeep Cherokee 4WD
Need to find where the thermastat is on a 2003 cadi
It is in the rear of the engine by the firewall and the intake manifold will need to be removed to gain access t it.
Engine Coolant Thermostat Replacement (LA3, LY9) Removal Procedure
  1. Remove the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
  3. Complete the following in order to remove the thermostat from the thermostat housing:
  4. 2.1. Depress the ears on both sides of the thermostat. 2.2. Rotate the thermostat until it clears the retaining feature of the housing. 2.3. Release the pressure from the thermostat. 2.4. Pull the thermostat from the thermostat housing.
Installation Procedure
  1. Complete the following in order to Install the thermostat into the thermostat housing:
  2. 1.1. Align the thermostat pin to the thermostat housing orifice. 1.2. Depress the ears on both sides of the thermostat. 1.3. Rotate the thermostat until it aligns with the retaining feature of the housing. 1.4. Release the pressure from the thermostat.
  3. Install the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
Jul 10, 2010 | 2003 Cadillac CTS
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
One bolt thermostat housing. How do I get the housing off?
remove the other bolt from the thermostat housing and remove the housing. My fear at this point would be that by removing intake manifold bolts and wiggling the manifold you may have damaged the intake manifold gasket set, which is a much more indepth repair
Nov 27, 2008 | 1989 Oldsmobile Delta 88
Comfort Zone 12 In Oscillating Table Fan - CZ121 Logo
71 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
