Question about Plumbing
Aquasource shower faucet temperature adjustment how to
2 Suggested Answers
cmartineau
  • 5 Answers
SOURCE: when shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Posted on Dec 01, 2012
I would like to replace my shower handle and skirt. Are Delta parts compatible with Aquasource?
go to your local plumbing supply they will give you handles and trim parts that will fit in different stiles for your brand faucet
Apr 13, 2016 | AquaSource Stainless Steel Replacement...
I have a aquasource faucet and the top button is stuck
Unfortunately, Aquasource is an imported faucet by Lowe's, and parts are not easy to get. You might want to visit a Lowe's and see if they have a replacement diverter unit for this faucet. If you can get one, it should take about 10 minutes to install, then you'll be like new again.
May 08, 2014 | Plumbing
Delta handle won't turn more than half way
Take the handle off and adjust the hot temperature stop. Its just a plastic piece that needs to be adjusted up more. It just fits in grooves like a gear. Its easy to do.
Apr 19, 2013 | Delta & Single Handle Shower Faucet
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
Nov 14, 2012 | Plumbing
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Have the moen 82300 2300 series positemp tub and shower faucet. can i make this a nonpositemp by replacing the cartridge? We are unable to regulate cold or hot temp. no matter where the handle is the...
Temperature regulating faucet, aka anti-scald, are fast becomring a requirement under local building codes making it, technically speaking, a building code violation to alter the faucets function (assuming someone reported it the loccal buildings dept. That said the function of the anti-scald faucet cannot be altered. You should contact whomever installed the faucet to come back and adjust it so the temperature is more suited to your needs.
Jun 20, 2010 | Moen & One Handle Tub & Shower Faucet
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
I have a new single handle shower valve and when i turn it to hot it only gets luke warm, i have taken the cover off and i see the brass piece with a screw in it but it does nothing to adjust it and when i...
single shower units are shipped in cold position as a safety u have to adjust ur anti-scold clips to allow hot water --- that red clip is ur hot adjustment-- if u have ur paperwork for the unit in it explains on how to adjust[ but]=== if u pull back the red clip [it sits on a spline of teeth] and turn it put back on so the valve opens do it in small increments till ur comfortable with hot adjustment will take a few times
Mar 01, 2010 | Moen & One Handle Tub & Shower Faucet
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Shower water temperature regulation
The temperature is adjustable. The valve has a disc you pull off the front of valve and then rotate the seat I believe counter-clockwise. If you get the paperwork for this valve from moen it is very explanatory. I can help further if needed, Let me know!
Nov 10, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
52 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
