Riello 40f5 burner how do I bypass electronic air shutter
4 Suggested Answers
SOURCE: ran out of oil, filled the tank, how do I bleed
You need a phillips screw driver a 7/16"wrench & a dish pan to collect oil.Remove cover. Left hand side is brass ***/nipple.7/16wrench fits on & loosen a half turn. Push reset button and observe oil/air purdging from brass fitting wait for steady stream in dish.Pinch/close brass plug.You may have to repeat this untill all air is gone.Once burner fires up your done!good luck!
Posted on Mar 24, 2010
Testimonial: "Did as you described... WORKED. MANY THANKS :)"
  • 5 Answers
SOURCE: Riello oil burner RDB Hi everybody i have a
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
Posted on Sep 25, 2010
  • 12 Answers
SOURCE: Riello oil burner problem -
BUrners trip on safety for a number of reasons. When the burner is working you should not see any smoke in the smokepipe. If you do then the settings are off and adjustments need to be made. If the unit does not actually light then the problem can either be with the nozzle, the oil pump or filter. Lastly, you may not be getting spark. If you get more specific I may be able to guide you through step by step.
Posted on Feb 02, 2011
I recently installed a new furnace ..with a Riello 40 series burner models f3 how many litres Of fuel should I be burning pr hour ..
The Riello 40 Series F3 Burner has a firing range from .50 Gallons per hour to .95 gallons per hour. The burner is adjusted by the tech for the proper BTU input.
Mar 09, 2018 | Heating & Cooling
Riello f5 oil motor will not start
Is your electric air shutter opening? That causes power to come on. Here's a link.
http://www.weil-mclain.com/sites/default/files/field-file/sgo-riello-oil-burner-manual_0.pdf don-ohio (:^)
Jan 19, 2017 | Heating & Cooling
How do i change a nozzle on f3 riello burner
I have a manual for this burner i can email it to you if you do not already have it my email is steve_e_morris@hotmail.com i will send it to you if you need it.
Dec 17, 2014 | Heat Controller Comfort-Aire Lowboy Oil...
Riello burner
You need to measure the manifold pressures before and after the gas valve and adjust accordingly to fuel used, 3.5" NG or 11" Propane.
Nov 06, 2013 | Honeywell Biasi B10-3 Boiler ,riello...
I have riello oil burner put oil into a empty tank tried to bleed it now it won't fire up can you help
is the filter clean u might of picked up sludge in bottom tank also blow out the supply lines and re fitt try again
Sep 23, 2013 | Honeywell Biasi B10-3 Boiler ,riello...
Riello oil burner RDB Hi everybody i have a Riello oil burner RDB . I am wondering is there a way to make it more oil efficient?
Sep 25, 2010 | Heating & Cooling
Ran out of oil, filled the tank, how do I bleed the Riello 40F5
Mar 21, 2010 | Heating & Cooling
My furnace is exhausting very fine black ash what causes this? It has a Riello Mectron 3 M burner. I have replaced the fuel nozzle, fuel filter and air shutter hydraulic jack. The turbulator setting is at...
The fine black ash is called soot, and is a by-product of incomplete combustion. The burner should be set up and adj. with the proper equipment. Your OEM specs are a good starting point, but without performing a combustion efficiency test, it is not possible to properly set up a oil burner.
Mar 15, 2009 | SySTOR Systems (400S52) Burner
Riello burner will not pump oil to nozzel to burn.
Revisit the photocell:
1. Check if you connected the socket end, into the two pins properly, as it is possible to miss a pin.
2. Try to borrow a working photocell or use yours in another burner to make a determination.
Dec 27, 2008 | Heating & Cooling
Heating & Cooling Logo
305 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
