Question about Sherwood Digi Line A/v Stereo Receiver Rv-5030r Pro Logic Works Great
How do you hookup other componants to the receiver
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
Cant get sound from my insigna 1080p lcd tv to go through my pioneer sx 315
I had to hookup a RCA Cable from the component audio on TV to component on receiver along with the HDMI cable to create a loop for the HDMI pass thru to work allowing audio.
Apr 08, 2013 | Audio Players & Recorders
I have a 32inch Phillips HD ready TV but there does not seem to be and HD input for my DVD player
"HD input" is HDMI. If the DVD doesn't have HDMI output then use the 5 wire hookup - the component hookup.
The TV input for HD would be HDMI or component input - 5 wires.
Nov 25, 2009 | Philips DVR-1
Hookup the comcast hd box to my new lcd tv?
You can use either component (Red/Green/Blue video and red/white audio) or HDMI cables to connect the Comcast HD box to your TV. Most times you can get these cables for free at the Comcast front counter.
Sep 26, 2009 | Onkyo TX-SR606 Receiver
I have hooked up my satellite receiver to my Dell 4100m using component cable. The picture seems weak and not very sharp. My computer hookup using a vga cable is bright and very crisp. Is there another...
First, make sure your receiver output is 1080i. This should allow for the best picture with the component cable. If you want it to be the best, switch to the M1 digital input. Note: some 4100 mp might have problems with the M1 input.
good luck
Jun 27, 2009 | Dell 4100MP Multimedia Projector
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Xbox 360 or Dish ViP 622
when i hook either my dish hd receiver up to the 1080i component video inputs, everything works fine if i set either device to 480p, but i get nothing i set them to 1080i.
Apr 09, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Connecting sony str/k660p to dvd recorder and tv
Hello jvirgil,
Go to http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK660P&LOC=3
and under the hot topics section, click on "Hookup Recommendation Guide", select the components you want to hookup (Dvd recorder and receiver in your case. TV hass been autoselected). Click continue, select all the different inputs/outputs that your components have, click on Recommend my Hookup and... 'voila' you get your personalized connection guide. Hope this helps.
cancerags
Dec 27, 2007 | Audio Players & Recorders
Sherwood Digi Line A/v Stereo Receiver Rv-5030r Pro Logic Works Great Logo
15 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
