Question about AEG Washing Machines
Aeg 16830 error E22
Occasionally stops cycle at point of drying with code e20. Tries steps in user guide, rear hose and fluff filter (front bottom right). Fault still at random. followed steps to get a code and see E22. Any suggestions ? Thanks
  • 5 Answers
SOURCE: error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
Posted on Jul 18, 2007
Coldcut
  • 1554 Answers
SOURCE: error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Posted on Jan 29, 2008
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
SOURCE: my aeg washer dryer comes up with e20 flashing
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
Posted on Jan 14, 2009
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
AEG OKO LAVAMAT 72630 is showing E20. what does it mean?
Error code E-20 means drain problem. It means that the machine is not draining water correctly. Check the drain hose, to see if it is kinked or folded over. It could also be that the drain pump or drain hose are clogged. Drain the pump (check behind the little panel at the bottom right of the machine), first draining via the small emergency drain hose if you want to avoid a large puddle.
Also get the fluff filter removed and checked.If the filter is clogged then it will not let the water to get drained. The fluff filter is behind the little trapdoor below and to the right of the drum on the front of the machine. Open the door, unscrew the filter, and pull it out. It will be covered in smelly slimy multi-coloured fluff, which you need to remove. When you remove the filter, there is a good chance that a fair bit of water will come out at the same time, so, if you can place a very low bowl or similar below the filter before you unscrew it it will save you from having to mop the floor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | AEG Lavamat 72640 Front Load Washer
Error code e20
E20 means you have a drain problem. Check the drain filter on your machine to make sure it isn't blocked by fluff/coins/etc. Should work again unless you have a bust pump (which I had).
If machine is full of water, do an emergency drain through the little pipe on the bottom front. Good luck.
Jan 18, 2010 | AEG Lavamat 72640 Front Load Washer
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
Error codes
Jan 28, 2008 | Maytag EPIC MFW9700S Front Load Washer
Error codes
I suggest you snake out the drain into which the machine waste hose goes, the standpipe that is. The drain could be blocked somewhere causing pressure problems which is conveyed to the machine. Be sure to replace the machine exit hose at about 3 feet from ground level, and dont shove it too much into the standpipe. Do not block up the point where the machine hose goes into the standpipe, it shouldn't be air tight.
Dec 28, 2007 | Frigidaire FTF530FS Front Load Washer
My aeg washer dryer comes up with e20 flashing i have checked the pipes, changed the pump cleaned the bottom filter, pump is now working but e20 fault still comes up half way through the wash cycle... how...
Dec 21, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Error codes
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
62 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
