Question about Mitsubishi WS-65809 65" Rear Projection Television
Picture problems with Mitsubishi WC-65809
The picture turns into a "negative" after 3 minutes. Don't know the problem, nor the solution. any help/insight would be appreciated.
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 10, 2008
SOURCE:
Mitsubishi WS-65809 Iris problem
i KNOW THIS SET WELL and it has no such option.
I am not sure if you really want an answer as you post this repeatedly and do not respond to comments.
picture is very dark and blurry?
Mar 30, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Tv shuts self off after 30 sec
It says it is a Mitsubishi WS-65809--can you confirm that?
Mar 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS 65809 65" Rear Projection TV. Turns
Hello There, Its seems that the circuit board has problems. You'll have to get it replaced ASAP before the board is ruined completely.
The same thing also happened to me 2-3 weeks ago. the techs came in and had to replace the board since 1 circuit was damaged.
It will cost around $100
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Jan 16, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 convergence problem
I know these sets very well and have posted instructions here for the chip replacement many times.
If you really need help I am in California and will be online noon until 11 pm tomorrow- (Pacific time) if you really want help post a question in the Premium section here attention SD TECH and I will help you more.
SD TECH
Jan 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My mitsubishi ws-65809 will not power up.
Mine is doing the same thing. I just talked to the repair guy. It is a power supply problem. Try unplugging it for 5 minutes and turning it back on. Also if you were having problem with any picture issues it is the convergance, and that requires chip replacement. They are estimating $350.00 to replace the power supply.
Jan 02, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Convergence problem I have an intermittent vertical convergence problem. I have to shut off the TV and turn it back on to get a normal picture again. Need to fix this problem. The TV is a Mitsubishi...
Good Day;
You have poor connections on your "convergence IC's. Middle board IC's on large silver heat sink. Redo solder before total failure. Good Luck, big IRISH.
Oct 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Flashing power light no picture
We would need to know the model number. you have indicated that it is ws-65809 but i don think this is your model because what you are describing is a bad dm module and the ws-65809 doesn't have one in it. Let me know and I can help your further!
Tim Nolan
Sep 21, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Ws-65809 no high voltage
HI INMARK66-THATS FUNNY I HAVE THE SAME MODEL BUT MY PICTURE TUBS ARE ALL GLOWING I HAVE SOUND BUT NO PICTURE EITHER.????DO U STILL HAVE PROBLEMS WITH THIS TV???IF NOT LET ME KNOW WHAT U DID TO IT???LOOKS LIKE U POSTED THIS AWHILE AGO??THANKS GLENN
Jun 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
