Question about Umarex Walther P99 RAM .43 Cal. CO2 Paintball Pistol - Black -
Umarex p99 won't shoot in semi auto mode only single shot then has to be cocked to shoot another ball.
When i take a picture it saves about 5 of the same pictures
Do u have multiple photo apps? Or u might have the auto-upload option enabled in ur settings. I went into my apps + turned alot of them off! If that doesn't work, do a soft reset, it'll definitely stop the madness!
Jan 28, 2016 | Android Apps
Crosman 766 was shooting fine, the next shot did not shoot the pellet and just made a funny sound. Now when you pull the bolt back and forth there is no sound to indicate a shot fired when the trigger is...
Upon cocking your gun is there the same tension with the cocking spring as there was befor? Also check the condition of your barrel seal for tears or cracks in it.
Nov 23, 2010 | Crosman ® Phantom .177 Pellet Rifle with...
How do i take a picture by myself using the self timer
Switch top dial to "P" or some other mode, but not "AUTO"
Press FUNC then scroll down two steps to "Drive Mode"
Then press right from single shot, to multi-shot to 10 second count-down.
Then compose the shot, press the photo shoot button and listen for the countdown beep from 10 seconds.
All done.
Mar 25, 2008 | Canon PowerShot A520 Digital Camera
Auto focus
Hi Wendy,
You mostly have the camera set into shooting mode "C" instead "S".
Some of those Canon cameras may say, "Single Servo Autofocus" and "Continuous Servo Autofucus".
Set to "S" as in single.
For more help: atdlee@netzero.com
Feb 13, 2008 | Canon 24-70mm f/2.8 Lens
Sequential shooting modes
There are four sequential modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the CAMERA menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: - Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. - High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. - AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. - Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Umarex Walther P99 RAM .43 Cal. CO2 Paintball Pistol - Black - Logo
Top Umarex Sport & Outdoor - Others Experts
Are you an Umarex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
