Question about George Foreman Brain Storm Smart Blender - GFSB1
George foreman brain storm blender leaks thru the blades
Leaks thru the bottom assembly
2 Suggested Answers
SOURCE: need bottom collar for the george foreman
I need the collar to your George foreman GFSB1 Blender
Posted on Jan 11, 2011
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
Contact Us Customer Service Vitamix
or check here:
Vitamix Wrench
Apr 25, 2014 | Vitamix 34000 Blender
Leaking
Unfortunately Kitchenaid's design on those blenders is a one piece unit, over time the seals wear out and you have to replace the entire jar assembly, they usually run 40-50 dollars and can be found from several vendors.
Here is a link to the replacement jar on our site: KitchenAid Blade Jar Assembly W10555711
Nov 28, 2013 | KitchenAid KSB560MC 5Speed Blender
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
Blender leaks from bottom.
mcdevito75 here, Best Bet, contact Black & Decker online or by phone for info, also see any appliance repair shop in your area.
Jul 09, 2010 | Black & Decker BL600 ProBlend Work Top...
The bobby flay blender leaks out the bottom where the blade is screwed in
Take it apart and pit the gasket on the other side of the cutter assembly.
Oct 04, 2009 | KitchenAid KSB3 Classic Work Top Blender
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
George Foreman Brain Storm Smart Blender - GFSB1 Logo
Top George Foreman Blenders Experts
eyecam
Are you a George Foreman Blender Expert? Answer questions, earn points and help others
