Question about Comfort Zone Heating & Cooling
E3 flashing on my heater - Comfort Zone Heating & Cooling
CZ 2020C Flashing E3, how do I fix it?
If you place a small fan behind the heater where the controls are it should quit stopping on you. There is a small thermal sensor that is getting warm and shutting down your unit. Its a safety item.. but it also works when you need your heater the most. So place that fan and it will blow the heat into your room better also.
Feb 08, 2015 | Heating & Cooling
I just got a life smart infrared heater took it out of the box plugged it in and turned it on and an E3 code is flashing wont turn on or any thing
What is wrong with my Comfort furnace, If it will not turn of when i push the off butting ?And even after that i unplug it and turn it back on ,it still comes on and will not go of like it use to with the temp control !!
Nov 30, 2013 | Comfort Zone CZ1500WC Infra-Red...
E3 flashing light wont heat
Check the filter. Some heaters will not work if the airflow is inadequate to prevent the elements from overheating. good luck.
Dec 13, 2012 | Comfort Zone Heating & Cooling
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Bosh tankles heater error.code e3
Copy following link for EXAMPLE E3 error code troubleshoot, to gather information to 'assist tech support in determining cause and solution to problem.'
http://waterheatertimer.org/pdf/Bosch_A3-E3_Error_Code_Troubleshooting.pdf
Contact Bosch 800-283-3787, or service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Sep 29, 2012 | Bosch & Tankless Water Heater
My bosch tankless water heater is flashing ae
Before calling service technician, open following links for Bosch error codes, and contact information, and possible product manual for your model, etc:
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
http://waterheatertimer.org/pdf/Bosch_A4-E4_error_code_troubleshooting.pdf
Error code AE is not shown, but error EA means "burner flame not recognized by control unit when water is flowing"
There is also error A3 and A3 E3: jumper connection is not correct
Sep 26, 2011 | Bosch & Tankless LP Hot Water Heater
Garrison tower heater flashed E3 code?
hi there, i just ran into the same problem i think i have the solution:
the E3 code is a "fall down" sensor shut off, what i think the problem is the internal sensor for when the unit falls over and shuts itself off is really sensitive. i had mine on carpet and it was acting up quite a bit till i wiggled it and put it on a more level surface.
hope this helps
Dec 25, 2010 | Vacuums
Is there a quick fix to a flashing e3 on a Danby DDW497W?
Refer the user manual for your dishwasher. Error codes are given on page 7.
e3 means the heater is not working or the thermostat (which checks the water temperature) is faulty.
Not sure there is any quick fix other than to replace. If the heater is showing some reading on an ohm meter then it is likely the thermostat is faulty. In any case it will be easier and cheaper to replace the thermostat first.
You will need to call Danby service closest to you for advise on getting the parts or servicing it.
Please rate this solution to help fixya serve you better in future.
Oct 06, 2010 | Dishwashers
Heating & Cooling Logo
15 people viewed this question
Top Comfort Zone Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
