Question about Ovens
Light not working in balay oven
I've changed the bulb in my Balay oven model 3HM509XT, the filament in the bulb had definitely broken, but the light still doesn't work. I don't have the instruction manual to help me, where can I get one from?
Why do oven light bulbs last only 2 weeks or so? Am using Philips 25w, 300 deg C rated, 1,000 hour life. AEG Competence double oven
Several things can shorten the life of bulbs. It could be a factory defect, the filament is receiving too much voltage,
physical shock while the filament is heated, vacuum leaks in the bulb seal or base.
Suggest try another brand preferably heavy duty.
Jan 16, 2018 | Philips Ovens
How do I change the oven light in this product
maybe a screw in bulb; you did not give make and or model..
Jul 02, 2015 | Ovens
Why won't light come oven is brand new straight out of box
The bulb filament may have broken in transit or it loosened in transit. It should be under warrenty.
Oct 07, 2014 | Ovens
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
Stuck oven light bulb
I use 2 sided tape to get a grip on the bulb. If it is really stuck and you end up breaking it, don't worry as it will be easier to remove the rest of the bulb with a pair of needle nose pliers.
Nov 23, 2011 | Maytag Amana 30 in. Electric Double Wall...
I have bought a Balay Electric Oven 3HB 516XP and the user manual is in Spanish how can I get an English one.
http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM
Pick the one that says EN to download
Mar 03, 2011 | Ovens
Kenmore oven model # 79071053400
Check for a loose bulb or faulty door switch. Sometimes a bulb can fail and the filament can reconnect to work at a higher wattage before failing completely.
Jun 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
