Cant turn alarm off
SOURCE: setting tha alarm
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
SOURCE: timex expedition indiglo wr 50m
I had the same problem, and could not find any answers on timex.com. After you place the battery in and it begins to beep, push all four buttons in at the same time. This should "reset" the watch -- at least it did for me.
SOURCE: LOST THE INSTRUCTIONS
I found this set of instructions on the timex website: http://assets.timex.com/instructions/w90Instr.pdf
They seem to be correct for this model. Good luck!
SOURCE: Timex Expedition watch beeping continuously please solve
Try to get solution here:
http://www.timex.com/gp/node/n/255235011/190-2521384-6105829?ie=UTF8&timexBrand=core
Rate, please.
SOURCE: TIMEX MODEL MF13/P8
Press all the four buttons simultaneously your digital clock gets resetted. It worked for me try it out.
Timex has two ways to find information about your particular watch. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
