Question about Delco 1983 - 1983 Plymouth Scamp Drive Belt Idler Pulley 38003 Air Co
CAR WONT MOVE AFTER PUTTING IN GEAR
WONT MOVE WHILE IN GEAR WITH NEW CLUTCH AND TRANSMISSION
    Master:
  • 613 Answers
Sounds like a disconnected linkage from the shift lever to transmission.
Posted on Dec 08, 2013
I replaced the transmission and my shifter isnt allowing me to go into any gear nor is it gong into drive......help please
Just off the top of my head ... since this is a manual ... are you sure the clutch is disengaging? Can you move through the gears with the clutch pedal pushed down and engaged?
Jan 19, 2018 | Cars & Trucks
Wont go in gear when on it only goes in gear when car off
It's a manual transmission, then? If it is, your clutch is not working. You need to check at the transmission's bell housing to see if the clutch pedal being depressed causes the clutch fork to move-either forward or backward, it should move about an inch with the pedal pushed to the floor.. The clutch pedal will either be cable operated, or it will be a hydraulic clutch with a clutch master cylinder on the firewall, and a steel tube going down to the bell housing, where a small "slave cylinder" operates the clutch fork.
If you see the clutch fork move a fair amount, at least an inch, then you probably need a new clutch disc and pressure plate. A clutch job means removing the transmission to replace the clutch.
If the clutch fork does not move, either the cable has too much slack-for cable operated clutches, or the hydraulic unit has a problem-for hydraulic operated clutches. One of your hydraulic cylinders may be bad, either the clutch master cylinder or the slave cylinder.
May 29, 2015 | Cars & Trucks
2001 Saturn SL transmission won't engage
hangon. your leaving something out. myguess is you had the ebrake pulled so the car didn't roll when it was in gear. and now the car wont move at all or what? you left alot of important info out. if it is running and wont move at any point you broke something in the trany or a driveshaft. you should not be able to shift the trany into any gear if the engine is running. the clutch is turning and unless the clutch is disengaged you wont be able to shift. knowing that i am guessing you broke it good and need a new trany
Sep 17, 2017 | Saturn SL Cars & Trucks
As I would drive the 2000 ford focus I'm not sure if it was the clutch or the transmission but its like the car would go to a lower gear for a minute and then catch back up. Then I happened to be driving...
I believe it's your clutch. If you can shift gears okay with the engine off, but you cannot shift gears with the engine running, (the gear shifter only grinds when trying to shift into first?) then your clutch has worn out.
To replace a clutch, the transaxle has to be first removed from the car. I'm afraid you will have to have it towed to a shop or garage.
Nov 08, 2013 | Cars & Trucks
My stick Audi A6 Quatro had some gear slip when I shifted, then a lot of gear slip, and now the car doesn't move. I can shift into any gear without using the clutch. The RPMs go up, but car does
Your friction plate is kaput. Replace clutch system. Sounds like the pressure plate needs attention as well. No idea of price but get prices of "clutch kit" on the web and you can have an idea.
Oct 08, 2012 | Audi A6 Cars & Trucks
Push on clutch and caR WONT GO IN GEAR UNLESS MOTOR OFF
Some of that model had an unusual clutch mechanism, which has probably broken due to wear. Read here
http://wiki.answers.com/Q/How_to_adjust_clutch_on_1995_ford_escort
In the event yours is instead fitted with a hydraulic clutch, either
- the hose has split
- the clutch throwout lever has broken or collapsed
Mar 21, 2012 | 1995 Ford Escort
I have a 1996 v6 3.0 taurus and my car turns on and you can accelerate the car but it wont move and i can put it on which ever gear and it wont grab the gear. i tried putting it on neutral and drive and...
hi, if this is a manual car, with clutch, then your clutch plate is worn and needs replacing, if it is an automatic, locate the dip stick for the fluid, while the motor is running, check fluid level, if it is not showing on dip stick you need to fill it, make sure you fill it with the motor idling not off, or you will not put enough fluid into the transmission for it to work...hope this helps good luck
Sep 13, 2010 | 1996 Ford Taurus
When i put in gear then let out on clutch the car
sounds like u have a worn out clutch or a faulty pressure plate
Jul 08, 2009 | 1995 Ford Probe
Nissan sentra 1997 starts but wont go when put in gear
is it a manual or automatic?if it's manual check clutch.if it is automatic check transmission fluid.
Dec 02, 2008 | 1997 Nissan Sentra
Delco 1983 - 1983 Plymouth Scamp Drive Belt Idler Pulley 38003 Air Co Logo
32 people viewed this question
Top Delco Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Delco Heating and Cooling Expert? Answer questions, earn points and help others
