Question about Sherwood RX-4103 Receiver
Rx4190 click off even when no speeker is connected
How can i connect speekers with just copper wire to my mixer with red and white jacks
You didn't list the model number of the mixer, but from your description, your mixer does not have power amplifier outputs for speakers. The red and white RCA jacks are out puts that would plug into a power amp input, and the speakers would connect to the power amp, as in a PA system.
May 21, 2014 | Audio Players & Recorders
Audio problems
Could you verify that the headphones are fully plugged into the jack? Also, go to the control panel and right click on your audio device. Go to properties then details. Try to search for a new driver using the hardware id.
Apr 24, 2014 | Acer TravelMate 4230 Notebook
Nad c355bee
Check to see if it works with headphones. If it doesn't then you might have a main power amp failure.
Aug 06, 2013 | Audio Players & Recorders
One day when someone called me i couldnt hear them. And when i call my phone does not even ring. any ideas?
its may be 4 network problem / head set not fitted properly/some blue-tooth issue.if its rapind then may 4 transmitter/ringar problem,if in lowd speeker tte ok,then oter ear speeker is gone.
Mar 27, 2010 | Verizon Communications Samsung Alias Cell...
Speekers on laotop wont work,the speekers on my phillips freevent x52 laptop wont work,ive tried turning the volume dials up to there full capacity ut to no avail
I have a Logitech X240 speakers, and I move so now I am trying to connect the speakers to another computer, I have it connected but there is no sound. Do I need the CD Software to be downloded?
Thank for you help.
Jan 08, 2010 | Philips Audio Players & Recorders
My 1984 S10 the back speekers dont work speekers are good speeker wire runs under the carpet but when i took out the radio there is no harnis for the back speekers
The Stipped down Stereo Model that was in a LOT of the S10 Trucks did not have Rear Speaker Connections. They ran only to the Dash and/Or Doors. This unit will need to be Replaced with an Aftermarket Head Unit to Remedy this Problem. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 27, 2009 | 1984 Chevrolet S-10
No sound resulting.
well that could be becouse your notebook cant support your speekers, becouse some stereo speekers reguires special sound card. how many speekers your logitech have?
Jan 08, 2009 | Computers & Internet
Speaker don't work
install sound drivers once again
Nov 29, 2008 | Everex DESKTOP PC EVEREX | GPC TC2502 RTL
Play cd and dvd but no sound
this is a simple problem in u r speeker so first remove u r speeker and chek the connections are perfect r not if the connectinons r fre fect then the problem will be in speker,i hope so the emiter is lost so once u see the connections and if u find nothin in it change the speeker then u r problem will be solved
Feb 25, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Jul 01, 2007 | Denon AVR-1507 Receiver
Sherwood RX-4103 Receiver Logo
24 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
