Question about Home Security
Rewinding recording I have a 2m technology security system and do not know how to rewind the recorded footage. How do I do this?
bmwrider
  • 215 Answers
SOURCE: Eating the tape
It sounds as if the takeup spool isn't doing it's job. It could be caused by a slipping belt or slipping clutch assembly. Unless you know your way around the unit (internally) I'd advise a repair shop have a look at it. BMW
Posted on Jun 07, 2006
SOURCE: Rewinding the tape stops after a few seconds and eject comes on. Also battery dies in 5 minutes.
I had this exact same problem, I was stressed as i have sold the camera and was just testing to ensure it still worked. I took this advice and used the charger plugged in direct to AC (bypassed the battery) and the camera now works. I will try recharging and discharging the battery a few times slowly. Thankyou so much for providing this advice.
Posted on Mar 26, 2007
Grubhead
  • 5113 Answers
SOURCE: Error F03
I suspect that only one capstan works, The belt driving it might be broken or something else on the drive.
Posted on Jan 27, 2009
SOURCE: Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
Posted on Jun 22, 2009
SOURCE: Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Posted on Aug 08, 2009
Tascam 238 recording deck will not stop rewinding.
Are you any good at surface mount circuit board repair? It seems that the caps go bad. Check out this: http://www.thegreatbear.net/audio-transfer/8-track-cassette-capstan-motor-tascam-238-syncaset/
Jun 08, 2014 | Tascam 2488 Portastudio Multitrack...
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
I just need to know how to erase. I've seen on
Hello Normally Press and hold Tel Record and Rewind
Dec 03, 2009 | Lanier Audio Players & Recorders
Rewinding to listen to recording
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported, though
Jun 08, 2009 | Sony ICDP620 Digital Voice Recorder
How do I rewind
by just pressing the rewind button, it goes to beginning. by press and holding down the rewind button, it will start rewinding slowly and get faster the longer it is being held down.
Jan 20, 2009 | Olympus WS-300M Digital Voice Recorder
Pedal problems
If the tape re-winds when you take your foot off the pedal then the auto-rewind switch on the right side of the machine at the back is set to number 3. Move it forward to number 1 or 0. If it really does rewind while your foot is on the pedal then I don't know what is causing that. Sorry.
Jul 07, 2008 | Audio Players & Recorders
Rewinding Troubles
return it to b+h for warranty repair. sounds like a tape path alignment problem.
Oct 12, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Why should I record my memories on a Hitachi DVD Camcorder?
The picture and sound quality of footage stored on a DVD does not degrade over time. Home movies can be shared with friends and family decades into the future in perfect and pristine condition. Motion video stored on a 8 cm (3 inch) DVD-R disc can be played back on most DVD players and compatible PC DVD drives. After finalizing the DVD-R disc in the camcorder, it can be placed directly into your home DVD player and played back. No additional adapters are necessary and you do not have to connect the camcorder to the television. With DVD, you can instantly access desired scenes without having to endure the time consuming task of fast-forwarding or rewinding. Through Hitachi’s Disc Navigation feature, you simply select the thumbnail image of your favorite scene and it begins to play immediately. 2005 Hitachi DVD Camcorders support four different types of recording media. For motion video you have the option of using a 8 cm (3 inch) DVD-R disc or a 8 cm (3 inch) DVD-RAM disc. Digital still photos can be stored on DVD-RAM discs, Secure Digital cards or MultiMedia Cards. Size Hitachi introduced the world’s first DVD based camcorder three years ago. Since then, Hitachi engineers have been able to perfect the technology and to reduce the physical mass of the camcorder by 45% making it the most portable DVD camcorder in the industry.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Home Security Logo
94 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
