Question about Briggs & Stratton Garden
Generac model G23 power washer no pressure
Loss of pressure
  • 109 Answers
SOURCE: on a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Posted on Mar 27, 2009
  • 28 Answers
SOURCE: I need the owner's manual for Generac Power Washer
Here is the link for your machine.
http://www.generac-portables.com/document/index.cfm?doc=1439_0EN3W_LO.pdf
Posted on Apr 11, 2009
rwvanlue
  • 486 Answers
SOURCE: How do i set the timing on a 6hp briggs and
The only timing is the flywheel key and the air gap on the ignition coil. Air gap should be 0.010-0.012"
Posted on Nov 22, 2009
SOURCE: I own a Generac power washer model 01292=1 type
Go to the Briggs and Stratton website and go to their generators then to Generac. You should be able to track down a link to putting in your model number. (4) PDF manuals show for that model. http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm?rd=1
Posted on May 22, 2010
SOURCE: Pump appears to be shot in Generac 2.3 gpm 6hp
Mine blew up. The OEM is ****. Went on-line to buy a similar but more powerful pump. There are lots of pumps that are an easy bolt on. It's mostly standardized. Google "pressure washer pumps"
Posted on Sep 09, 2010
My new 2500 psi generac power washer will not start
is it getting fuel ? Do you know if it is getting a spark ?
Sep 14, 2013 | Generac Pressure Washer - 6020
I can not find how much oil to use in the Generac Pressure washer 2700.
the only thing i can suggest put your pressure washer on level surface and start fill the oil when gets to the right level the oil start coming out
Apr 19, 2013 | Generac Generator 5989 2,700 PSI 2.3 GPM...
How much oil do you put in the pump for a generac pressure washer model # 01676?
Check and see if there is a sight glass on the side of the pump. If there is, just fill it until the oil shows up about half way in the sight glass.
Sep 23, 2012 | Generac Generator 5989 2,700 PSI 2.3 GPM...
I own a Generac power washer model 01292=1 type 6670CP GPM2.9 PSI 2300 and request the owners manuel for this model Thank You Al Bonfardino albonfardino@yahoo.com
Apr 30, 2010 | Briggs Garden
How do i set the timing on a 6hp briggs and stratton pressure washer? mODEL g23
Nov 22, 2009 | Briggs & Stratton Garden
GENERAC POWER WASHER PUMP
Check the pressure limiting bypass valve. Also make sure the replacement bolts are "rated". They must be a certain "grade" which defines their load rating. Make sure they are torqued to spec.
Sep 10, 2009 | Plumbing
On a generac pressure washer that works fine.
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Garden Logo
77 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
