Question about KitchenAid KAWS750L Top Load Washer
Size of KitchenAid KAWE777BWH1 Top Load Washer
Waht is the size (cu. ft.)of KitchenAid KAWE777BWH1 Top Load Washer
4 Suggested Answers
SOURCE: KITCHENAID TOPLOAD MOD KAWE777BWH1-NO
PUBLIC LIBRARY--WIRING DIAGRAM RECONNECTED ALL OK
Posted on Nov 24, 2009
SOURCE: leaks water on floor when using the largest load cycle..
Dap free registration code
Posted on Apr 16, 2010
mrbobfixit
  • 259 Answers
SOURCE: how difficult is it to replace the motor coupling
Here are some step by step instructions, They seem daunting, but what do you have to loose by trying yourself?
Accessing this part requires you to flip up the control panel by removing two phillips head screws in the front bottom corners of the constrol panel. Pull panel forward and lift to diengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way. Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it. Now using a flat screwdriver pry the front of the two brass clips towards the rear of the washer (put tip of screwdriver into fron most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it on the floor to gain access to the inside of the machine. The bottom front of the tub is where your pump and motor are located.
You will have to un-clip the pump from the motor and pull it off and out of the way, next remove the two screws that secure the motor clips to the transmission bracket. Disconnect the wires that go to the motor, and pop off the lower then upper motor mount clips- hold the motor because it will fall. Now you can replace the coupler. The coupler is pressed on to the motor shaft as well as the transmission shaft. You may need to use a flat blade screwdriver to pry off the old one and a socket larger than the shaft diameter held in place and tapped with a hammer to press the new ones on. Only press them on so far that the shafts are just flush with the coupler openings.
Good Luck!!
Posted on Jun 26, 2010
What is the size of this model? how many cu. ft?
This category includes standard-size top- and front-loading clothes ... Frigidaire. GLWS1649A. 449 $45. T. 85. 1.57. Frigidaire. GLWS1749A. 543 $54. F. 75. 1.26. GE. WCXH208A.
3.2 cu.ft
Oct 21, 2010 | Frigidaire GLWS1649A Top Load Washer
I have a Kenmore 60 series model number 110.92560100 and need to know the CU Size
Hi again. The capacity is 3.2 Cu Ft. or 12 - 14 lb load.
Thanks for choosing FixYa.
Kelly
Aug 26, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine shakes (off balance) during spin cycle, no matter what
3.2 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Size of washer
Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
Go to Sears.com and look @ the washers available
Jun 06, 2008 | Kenmore 22422 Top Load Washer
KitchenAid KAWS750L Top Load Washer Logo
60 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
