Question about TOP FIN reg Power Filters and Filtration Cartridges Power Filter 30 with Adjustable Flo Rate
Top fin filter won't start flow of water - TOP FIN reg Power Filters and Filtration Cartridges Power Filter 30 with Adjustable Flo Rate
1999. Why is A/C air flow poor?
air flow from and air conditioner is dependent on the condition of the heater blower fan
so check that the blower fan is operating at all fan speed settings
next if you live or use the vehicle in dusty conditions , the dust will build up on the evaporator fins ( condensate water and dust = mud and gunk) and blocked evaporator fins ( this will result in reduced ac operation as well
the dust is not always from out side air through a cabin filter ( may be blocked) but from dirt that is introduced into the cab from dirt on the foot wear
Jul 31, 2015 | Ford F-250 Super Duty Cars & Trucks
Hayward h300 pool heater won't start
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Sep 17, 2012 | Hayward H-series Electronic Gas Pool...
Sysrem keeps saying low flow
Three areas that can cause low flow 1) the intake on the pool, if you are using the pool sweep basket feature, then undo the connection at the pool wall and you will find that the wall filter is plugs with fin bug particles that can not make it past the wall screen. Clean and replace the hose to the wall. 2) the filter is clogged and dirty, clean the filter clean the filter compartment and replace, 3) you have an air leak allowing air to enter the pump system causing air to restrict the flow of water. Check the hose connection for leakage, check to make sure the bleeder valves are not loose or over tightened, as both will cause an air leak.
Aug 14, 2012 | Intex Automatic Salt Water System for ...
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-AirĀ® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
Blowing air out ,not pulling in
It may seem like no air is being pulled in - but air must be going in if air is being blown out. The air coming has to come from somewhere. It is more likely that the air flow is restricted.
This appliance has a reusable, washable filter. It should be checked regularly and cleaned as needed to allow the free flow of air into the appliance. A dirty filter restricts airflow and reduces efficiency of the appliance. It can also cause frost to clog the fins, too. If this happens, shut off and allow to thaw. Clean the filter, shake off excess water and reinstall. Power up the appliance again and it should work as expected. Do not operate the appliance without a filter installed. If you do, the fins will clog with dirt and are much more difficult to clean than a filter.
I hope this helps and good luck. Please rate my reply - thanks.
Apr 24, 2011 | Haier DE65EJ Dehumidifier
Fills with water and then stops and beeps and won;t continue. The hot and cold water buttons are flashing. Waterr starts trickling in and it is slowly spinning but doesn't seem to agitate
Hi just read your posting.The 2 lights that are flashing means your machine has not detected any water level difference.1st turn off both hot and cold taps and 1st remove the cold inlet hose from the machine end,Put the end of the hose into a bucket and turn the tap on.You should get a good flow of water.If you do not get a good flow of water then remove the tap end of the hose and see if you are getting water out of the tap.Check the inlet filters on both ends of the hose to see if they are blocked.If they are blocked clean them with a brush.Check also the water valve end where the hose connected to the machine to see if this filter is blocked. Once you have water coming out of the hose and all the filters are clean refit the hose and repeat to the hot hose.Now select a cycle and push start.If the water flow is good then the machine will work properly.If you still get slow water even when you have good pressure coming out of the hoses then your water valves are faulty.Please reply on how you got on and for further advice.looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Window unit spitting water out of air vent
Possible thatt due to non cleaning of the filter the cooling coil fins have got choked with dirt. The condensation of water on the coils will make it flow out of the area instead of dripping down to be drained out through the chassis out let..
So open the front grill, remove filter and use agood air /water jet to clean well so that there is air gap in the fins.
This must clear the issue as water will drop down to the back side to the chassis to be drained without any spill.
Sep 03, 2010 | Samsung AW1203B Air Conditioner
Saltwater pump keeps reading low flow...but water is flowing throught it...have already ckd the flow sensor..the filter pump seems to not sound the same as it did before the new filter went in...pool only...
sounds like air lock
Start by closing your plungers
now get the cartridge out and drain the lower bleeder screw
put filter back in and the cover ring
now open the top bleeder screw on top of the cartridge cover
open the other bleeder screw on the pump itself if there is one if not go right to opening the plunger that discharges the water
When water start coming out of the bleeder on the cap open the intake plunger
wait 5 seconds then turn your filter on
wait 1 minute then close all bleeders
This should do it
Jul 06, 2010 | Intex Automatic Salt Water System for ...
Top load washer, starts l flowing water normal and
Check if there is not a blockage in the supply pipe or the gauze filter at the connection at the back of the machine.
Jun 24, 2010 | Maytag PAV2300 Top Load Washer
Runs great but no water in bucket ,whats wrong
either there's no moisture in the house (especially if you have an air conditioner), the coils are not cold enough, or there's no air flow across the coils. if the latter is the case, clean off the rear coils, clean off the front filter (or if no filter, the fins), and see if the fan is working. cleaning the condenser coil fins in the front would also help with it not getting cold, if that were the problem.
Jul 29, 2009 | Fedders A7DH45B2A Dehumidifier
TOP FIN reg Power Filters and Filtration Cartridges Power Filter 30 with Adjustable Flo Rate Logo
266 people viewed this question
Top TOP FIN Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a TOP FIN Water Dispensing and Filtration Expert? Answer questions, earn points and help others
