Question about 1994 - 1996 Peterbilt 200-33 Engine Coolant Thermostat Seal 252
Heater hose diagrams - 1994 - 1996 Peterbilt 200-33 Engine Coolant Thermostat Seal 252
  • Vicky Pratt Nov 19, 2013
    I have a 1994 PETERBILT that I need the COMPLETE HEATER HOSE DIAGRAM. We just got this truck and it had already been work on by someone else. If any one can Help Me PLEASE let me know. THANK YOU
    Novelist:
  • 84 Answers
The interior cab heating system is identical to 4-wheeler cars. Two hoses connect to the cab heater core box, which is part of the engine radiator coolant system. If you're not getting heat when you turn on the heater fan, then one of the hoses is blocked or the heater core box is blocked up. One hose is inlet, which brings hot coolant from the engine to the cab heater core box. The 2nd hose is outlet which returns the coolant fluid from the heater core box back to the engine coolant system. Its likely these hoses and the heater core box are 20 years old and had never been replaced since the semi truck rolled off the assembly line in 1994. To diagnose for blockage, disconnect both hoses from the engine side, then connect an air blower to one hose to push pressurized air into this hose. Air should be coming out the other hose. If there's no air, or less air pressure, then there's blockage which is restricting hot coolant from passing through, resulting in little or no hot air when you turn on the "hot" air fan. Replace the heater core box first. If you're not getting hot air, then replace both hoses next.
Posted on Nov 29, 2013
Heater hose diagram. 2001 Ford Taurus
Go to TASCA Ford parts and they'll have a diagram of the hoses,probably. Also a place called Ford Parts Giant. don-ohio
Mar 13, 2017 | Ford Cars & Trucks
2003 ford windstar, my heater hose is leaking at the connection to iron pipe, I need a diagram to figure out how to fix
Most likely while you are in there it's time to replace the hose. Saves having to go back if it starts leaking on the other end which is highly likely given the age. There should be a return heater hose, it is probably in similar condition. Diagram may be available via google. Youtube may show you how to. A very bright led flash light will allow you to see and trace the heater hose. You'll need to drain the radiator save the antifreze if new. Replace if old. Any other cooling system hoses need to be replaced? How is the water pump. It's not the leak is it? Otherwise Library probably has repair manual, or may be time to invest in repair manual. Lightly used may be available on Ebay and others. New hoses are cheap insurance against possible failure.
Feb 27, 2015 | Ford Cars & Trucks
No heat. blower ok. engine temp normal. Can not locate the heater hoses to check if both are hot. How do I get access to the hoses? Is there a diagram?
Without more specs re: engine size etc, I'd have to say look close at firewall between engine and cab for hoses /tubing going into passenger compartment through firewall.
Nov 23, 2013 | 2000 Dodge Stratus
My heater hoses have been removed and bypassed. I need a heater hose diagram for my 1998 chrysler town and country van with a 3.8 L. I don't know which hose will plug into which heater core tube
That's easy
Drive around back of a dealer,walk in the open
service bay doors & ask a tech to come out &
tell you.
I walk into dealers all the time, anywhere I want to go,
& never get stopped
If your questioned your just looking for the parts dept & leave
Feb 01, 2013 | Cars & Trucks
1991 honda accord heater hose diagram
I have a 1993 honda accord ex that leaking water behind engine near my oil filter it was leaking water above it How do I fix the hose show me how
Nov 29, 2011 | 1991 Honda Accord
Want to find heater hose diagram
please rate. thanks.
Heater Water Hoses
Item Part Number Description 1 N610956-S56 Screw 2 18472 Heater Water Hose, Supply 3 18472 Heater Water Hose, Return A — Tighten to 7-9 Nm (62-79 Lb-In)
Sep 18, 2009 | 1996 Ford Windstar
New Motor, Heater not working, Leaking Antifreeze
Your car is overheating because you did not bleed the cooling system. The hanging hose may be the overflow drain. Unbolt the coolant reservoir, and raise it as high as you can. Start the motor, and add coolant until the heater starts blowing heat. You will see air bubbles in the reservoir until all of the air is out. This is a common procedure when doing any cooling system maintenance on Celicas.
Feb 22, 2009 | 2000 Toyota Celica
1994 - 1996 Peterbilt 200-33 Engine Coolant Thermostat Seal 252 Logo
289 people viewed this question
Top Stant Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Stant Vehicle Part and Accessory Expert? Answer questions, earn points and help others
