Question about Indesit Ariston Fridge Freezer Door Hinge C00144877
Lamona E9 fault - Indesit Ariston Fridge Freezer Door Hinge C00144877
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
Lamona microwave fault fault. When we close door, light and turntable working automatically but not heating. Please note unit is 27 months old
When you close the oven door, some micro switches are working. One of them is blocked. Check and replace the malfunctioning switch.
Nov 12, 2017 | Microwave Ovens
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Jun 01, 2017 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
What does the fault E9 mean on our Fisher & Paykel DW60CC dishwasher mean and how do we fix it?
The fault E9 means the controller has a problem. Obviously it is not a complete fault as you are still getting the fault codes. Some key circuit in the controller has become faulty and this prevents dishwasher from working. Usually the controller needs to be replaced. But first try to turn the mains power off and back on after a short delay. This might reset the controller (boot up).
Dec 09, 2012 | Fisher and Paykel Dishwashers
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
NEC washing machine displays E9
fault code e9 relates to pressure sensor.
check connections or replce pressure sensor
Apr 29, 2008 | Washing Machines
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Indesit Ariston Fridge Freezer Door Hinge C00144877 Logo
65 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
