Question about Ovens
Gorenje oven F27 indication on the display
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
Built-in oven-- clock unresponsive
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
Oven locked !
You will need to press and hold the clear or stop button for at least 3 seconds, if it is locked due to a cleaning function you will have to wait for it to cool down until it allows you to open it. You could do a hard reset and flip your circuit breaker for your kitchen off and then back on a moment later and try again.
Nov 21, 2013 | Ovens
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in www.repairclinic.com
Hope helps.
May 02, 2011 | Magic Chef Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
I DON'T KNOW HOW TO SET THE OVEN TEMPERATURE.
Normally you just turn the dial to the required temperature as indicated on the dial.
Usually the oven dial will say 'main oven' or have a symbol indicating which it is.
Sometimes it is a digital display and you have to press a button until the required temperature is displayed.
Dec 22, 2009 | Kenmore Ovens
I need a handbook for a gorenje gas hob and fan oven
Hi
You need o call Gorenge and they will send it if they have it.
0845 050 8555 UK
please leave feedback
Feb 11, 2009 | Ovens
Gorenje B3350E
Briefly press the first two buttons simultaneously (the button that says Timer with a picture of a bell and button with a picture of a steaming pot). You should now be able to set the time with the jog dial. It automatically starts the time a few seconds after you release the jog dial.
I have a Kleenmaid TO400 in Australia and it's the same as the Gorenje B3350E. Thankfully I have the manual as this would be impossible to guess
Aug 03, 2008 | Ovens
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
