Question about Refrigerators
Ge lw18jyvlw1 1)Kindly let me know what date this refrigerator was manufactured? 2) Is the noise level of the motor (on & off) common with this model? 3) There is water leaking and accumulating under the vegetable tray -- what can we do to stop this occurrence? Thank you
  • 198 Answers
SOURCE: water accumulation under vegetable drawer model
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Posted on Jun 17, 2008
mikedurland
  • 481 Answers
SOURCE: Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Posted on Jul 06, 2008
SOURCE: I have water puddling up under my Vegetable bins
Our fridge had the same problem with water under the crispers. My husband removed the slide out bottom out of the freezer section and exposed the galvanized trough that drains the defrost water into the drainage tube that goes to the tray under the refrigerator. Hallelujah! the galvanized trough was rusted through and allowing water to drip into the refrigerator instead of the drain hose. I have not found the trough on any parts lists so he is patching it with putty.
Posted on Nov 18, 2009
smuschanow
  • 20 Answers
SOURCE: WATER LEAKING IN BOTTOM OF REFRIGERATOR UNDER VEGETABLE KEEPER
This sounds like the problem I responded to for another user. I hope it works for you. I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
Posted on Nov 25, 2009
  • 3 Answers
SOURCE: We have a freezer top refrigerator...it's leaking
They normally have a drain hol at the back for condensation which can get blocked, if its more serious http://www.fridgeshop.net/ are very helpful.
Posted on Feb 27, 2010
GE side by side freezer, rhythmic whirring noise coming from freezer, at the top near ice maker.
Typically the freezer fan motor should be replaced, the issue usually lies with the tachometer within the fan motor, the main control board is not sensing the proper speed of the fan motor and therefore can't operate it correctly. In many cases the main board gets replaced too to ensure the most up to date software, as GE has had NUMEROUS software revisions on those main boards over the last 11 years. You would need to capture the complete model number from the appliance it's self in order to see if your main board has had preceding part numbers. Pleazer Appliance...
Apr 19, 2014 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile Side by Side TPX21PR/Tpx21BR. The freezer is not freezing ice cream or even bread, but the meat seems fine. There has been a loud noise emanating from the unit for over a year.
Kindly provide few more details so that i could provide more appropriate solution to your problem :-
1. How old is the unit?
2. Kindly hear the noise - Is it from the freezer section or upper back or lower back of the refrigerator?
3. Do you hear the compressor running?
4. Any problem with temperature in lower section or is it limited to freezer section?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 21, 2011 | GE Refrigerators
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser won't shut off nor will the ice dispenser motor
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
GE GSS20IE Ice Maker
Even though the fridge was given to you it still has a 1 yr warranty from manufacture date.  Look on the sticker inside the fridge and see if it gives the manufacture date or get the receipt from you gave it to you.  Call 1-800-905-9505 for service.  They are nationwide (US).  If you find out it is older than 1 yr then use the model # on that sticker and go to www3.sears.com to get the correct part # for the icemaker.  Unfortunately these come as a whole unit and can't replace parts.  Once you have the correct part # I bet will find a good price on ebay for a new ice maker.  If you need help finding the part # or any other questions let me know.  If you feel I didn't help solve your problem please let me know before you rate this solution.
Oct 12, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
