Question about iLO LCT32HA36 Television
My Speed con TV is showing FACTORY S1650S : 110113V3 code in screen
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
Multi colored vertical lines near the ends of the screen and a few about the center, tv is almost three years old 2008
Does it look like one of these picture?
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Does the on screen menu look OK?
Bad power supply, bad T-CON, bad LCD panel can be the problem depends on what exactly is showing on the screen.
Learn about T-CON/LCD panel failure mode here:
http://www.mediafire.com/?zzjygannjty
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 26, 2011 | Sony Bravia V-Series KDL-52V4100 LCD TV
1/4 of my sharp aqous tv has lines in it
This lines are in colors or black vertical lining in shaping?Yes?These lines are not causes by u or causes by an object by using forces hitting the LCD screen panel itself to causes these problems?Yes than the LCD screen panel are dying and leaking radiation can't be repair only by replacing new LCD screen panel not worth replacing and reparing if require a new LCD screen panel only.If these vertical lines are in colors or black are showing up and causes by the tv itself?Yes.Than the tv have a dying board that call the T-CON board and this board only job are docoding any pictures pixels before it showing up to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjmmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Aug 26, 2011 | Sharp LC-52D62U 52 in. LCD HDTV
One side of the tv has a black shadow and then theres all kinds of lines and no picture sanyo Dp46849 1YEAR WAARRENTY HAS EXPIRED \r\nsince this a factory defect will sanyo replace or repair?
Hello
The video output sectioon of your tV is faulty. It has to be replaced as card basis. No repair is possible on it, as it is a machine pressed soldered board. If the set has still warranty, get it repaired bu the authorised service center for Sanyo. The board is a little costly one too. OK.
Aug 04, 2011 | Sanyo DP46849 46 in. HDTV
My tv turns on but it shows colored verticals lines all over the screen then turns off
If this problems,the tv is causing this by itself,not by somebody or something hitting the LCD screen panel by causing the damaging the LCD screen panel itself.If this problems is causing by the tv itself,the T-CON decoder board is dead.This T-CON decoder board sit wright at the middle bottom of the tv LCD screen panel.Replace this T-CON decoder will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Nov 12, 2010 | Sylvania LC260SS8 26 in. LCD Television
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 29, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
iLO LCT32HA36 Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
